D
Deleted member 43491
Guest
Build now listed under
M416 build by RocketmanDane
http://www.expeditionportal.com/forum/threads/73129-M416-Build-by-RocketmanDane
Ok so I have 2 M416 trailers I have located and am looking to purchase one of them in the morning. That means I have about 10 hours to make a decision which one to buy? I plan to convert the trailer obviously into a expedition trailer I can pull behind my 2008 Tacoma. I would like as much input as I can get by the time I go back in the morning which to buy…. I will make a post and then reply with additional photos. The first trailer is 300 dollars and is in rough condition frame appears to be pretty solid a little bit of surface rust but the body is a different story. It appears the whole bottom and possible a little up the sides need to be removed and replaced. The axle has been swapped out for a 5000pound axle off a mobile home. It also has a additional piece of square tubing which the hitch is attached to a 1 7/8 in ball. No wiring and no lights. The second trailer appears in much better condition very little visible rust and is 600 dollars, frame appears to have little surface rust, has hand break and a 1 7/8 in ball. Has 5 lug tires. Appears to have a attached wiring harness and some lights and reflectors. Tires appear in so so condition.
Both do not have tailgates but the 2nd one for 600 comes with a spare the rim appears ok but tire is junk.
Question being which is the better trailer for the money?? Am I better off to go with the 300 dollar or the 600 dollar trailer?? I am leaning towards the 600 dollar trailer but the other is only 300…. I cannot buy both of them.
Or pass and keep looking??
