My GX470
DanKunz
I have a build thread in the LC section, but I will put one here.
Complete:
1 x ACC Toyota custom rear bumper with swing out and LED lights in spare
1 x Marlin Crawler RCLT front suspension
1 x 200 series steering rack
2 x RCV long travel CVs
1 x Icon long travel with S2 secondaries and rear omega
1 x Dobinson 849 rear springs
2 x rear FJ upper spring cups (GX does not have spring cups or perches)
1x Diamond rear axle with 9.5 land cruiser diff. 4.88s and ARB lockers front and rear
1 x RCI full skids
5 x 37x12.50R17 Fury RTs on Alpha beadlocks
1 x Iron Man Prado front commercial deluxe bar
1 x Iron Man Prado snorkel
1 x Iron Man 12000 winch
1 x full LED kit from PFRAN LEDs
1 x kick butt Alpine stereo, amps, speakers (Alpine and JL Audio) with aftermarket sub in stock enclosure.
1 x ARB twin onboard air
1 x ARB Elements fridge on drop down MSA slide
1 x ARB drawers with Jack and all tools onboard
1 x Wilwood 6 pot front BBK
1 x Ceike 4 pot rear BBK
1 x 21" LED light bar running on OEM switch
1 x Removed flares and bed lined flare pattern
So much more! :)
DanKunz
http://gromaudio.com/store/usb_adap...sb_ipod_adapter_direct_digital_interface.html
They have a harness included and you simply plug it in in-line to the CD changer and it is controlled by pressing specific OEM buttons. It will essentially allow the use of any aux input through the factory speaker and also allows for Bluetooth phone use (it comes with a microphone you can install, I put mine by the overhead console).
I installed mine behind the passenger dash attached to the wiring harness and ran the BT behind the center vents and the USB to the glovebox. If you have a gen1 ipad it will charge, any newer and it doesn't draw enough, so I got a cablejive unit:
http://www.cablejive.com/products/dockStubz.html
and ran mini-USB to it. I use a Blackberry compatible charger from the AUX power port in the center console. The unit I have has a coiled cable to charge my BB and 2 USB ports, one run up to the cablejive in the ipadholdr mount (Edge Series) with a Lexus mounting kit and a RAM mounting surface.
Cablejive:
The mount:
This is the bracket that attaches to bolts behind the wood trim above the glovebox and is a VERY clean install.
I used the 6" arm:
I had to trim the spacer in the Edge to fit the mini-USB for the cablejive, and also got a slim USB connector and trimmed it as well.
Works wonderfully!
Ryanmb21
Dan - thanks for posting this info.
Does that mount hold the ipad without too much vibration. Is it the same as the panavise mount? I bought the panavise to hold my HAM radio but would rather use it for the iPad if it will work. If possible could you post a picture of how it looks in that spot? I would greatly appreciate. I hadn't heard of the GROM system either, I'm anxious to research it a bit more. Does audio 'stream' through bluetooth or go through the auxiliary cord?
DanKunz
GROM BT won't stream through apple products, everything else will work (due to Apple's snotty BT policy).
Here are a few pics of how I have the mount. No vibration since I used the ipadholdr sticky pads to wedge it against the climate control display:
Mount from ipadholdr..very nice, I used a piece of window shim wood to tighten the fit (plan on coloring it black with a marker):
ryandavenport
Was your 2nd picture of the first post taken at Coal Creek? It looks like that is on Trail 22 up there. If so, it would be awesome to wheel with you sometime. I come up there quite often with FJs and Xterras.
Sent from my DROIDX using Tapatalk 2
DanKunz
Sure is! PFran (100 series) and I did a whirlwind day trip. I am only 3 hours from CC and love it there!
ryandavenport
Awesome! I'll try to let you know next time I go up there. Im 6 hours away from it in West TN
DanKunz
Thanks. I am treading new ground on a lot of stuff so there is a lot of research. I am hoping to knock out most of my list this year and focus on saving for the long arm kit and diesel conversion in the next two years. I have to have it all done within the next two years so I can focus on my oldest son's car (he will be 14 by then and I want to build a truck with him as he approaches 16).
