Thoughts on locks/deadbolts?
pods8
So this factors into my build but I'm curious thoughts on locks/deadbolts for campers.
For my build I have some of the typical camper handles with integral deadbolts. However these locks are pretty dang generic and for instance the same key sets I got with my new locks would open the locks on my old FWC. I don't know if some key numbers are more common thus the reason that occurred or what. Looking up the stats there are 50 combinations so the odds are against getting the same one, however you can buy a keyring with all of them if you want. So generally speaking there are decent stats that if you were ever in a area with a bunch of campers odds are someone has a key that would match your rig. Now granted people are generally good folks and heck you can usually just un-velco a normal pop-up trailer side to reach into it.
Typically adding a deadbolt isn't a big deal and adds a layer of security. However this is where my build challenge factors in, my top half comes down and covers part of my main door where my locks/latches will be and a typical deadbolt has quite the projection. The thought that pop'd in my head is to use an interior locking only deadbolt if the wife really wants one (the outer plate on those projects much less). If I do this to lock/unlock the main door deadbolt would require opening the access panel (in the lower part of the main door to get into the camper when the top is down) and reaching up to turn the knob. With that I mind I just foresee not really using the dang thing so part of me says don't bother. If we're really concerned drop the top down (which overlaps over the door and thus you can't use the main door). Installing a normal deadbolt on the access hatch isn't a challenge, but again circles back to really needed or no...?
Anyways I'd like to hear thoughts from the crowd as I'm going in circles and need to pick a path soon to knock out a door design and keep progress going.
cwsqbm
Are you more concerned with the lock when you're in the camper, or when you're away? For security when it it, a slide latch would be as strong as the material its fastened to, and have no exterior projections.
pods8
Yeah good point for the main door lock (if desired) just slide latch the dang thing since either way you're reaching in to actuate something. I'd have to tweak the trim around the door slightly for it but not a big deal. I was focused on a deadbolt thinking I'd get outside access but the second I looked at the interior actuation only it doesn't make sense anymore. Thanks for the reality check there, lol.
I'd say generally security when away BTW. But since I'll have a hatch in my door I could actuate a slide latch still and then deadbolt that hatch.
java
If someone wants in they will get in. A deadbolt wont stop them. Id say stick with the RV handle deadbolt combo to keep honest people honest.
Overland Hadley
on a journey
When outside the camper, I feel that you need enough lock to keep semi-honest people honest.
It is nice to have a solid lock inside the camper. It is good to feel secure when sleeping at night.
java
Completely agree. But i can get just about every deadbolt other than a Schlage open in under 10 seconds.....
pods8
I grant anyone can get into anything. However its slightly different that tons of similar keys (or potentially master keys) are walking around with folks that have a camper. Normally its a non-issue but if ever visiting national parks, etc. if could factor in. Again most folks are good but mischievous teens, etc. could be an issue.
DanoT
One time when pulling a 5th wheel trailer I did not bother to use the dead bolt while under way. The result was that after going around a corner the trailer flexed and the door popped open.:Wow1:
MakersTeleMark
I've been wanting to add one for both reasons stated above. Probably my next mod. Yes, I've had the door fly open, and yes, I've wanted a little bit more security for my stuff inside. Post up what you do. I'm thinking just a generic residential deadbolt.
hoptroll
Pool Boy
I have been thinking about this a lot as I have been dabbling in the pop up camper market. I would be more concerned when parked somewhere that someone could easily break the window on the door of most campers and reach in and simply open it from the inside. Thoughts?
Overland Hadley
on a journey
It is just to keep honest people honest. If somebody wants to get in they will break a window. Just like with locking the doors to your vehicle, it only keeps somebody from from opening the door without breaking a window. I guess the same goes for locking the doors to a house as well.
homemade
On my now 9 year old home built camper I used a Slage deadbolt and polycarbonate for the rear window, the doorframe as well as the frame of the door itself is steel. It really wouldn't be very amenable to break-in, at least though the door.
pods8
In my case when the top is don't there really isn't a great way in unless they break through two overlapping windows. Though a reciprocating saw would get you inside if really determined.
perhaps you can use these? Door Hasps
Someone could lock me in then, eek!
OH or others with marine experience are perko locks worth a darn or fairly flimsy and present the same key issues as RV locks?
project13support
