dustboy
Hi folks-
I just finished building this 6x12 cargo trailer conversion. It's got a full-size bed, running water with 21-gal tank, 12v electric system, all of which is removable by forklift so I can use it on Monday to deliver cabinets.
It's not really built for overlanding, but I do need some help making it travel better off of paved roads. We tried to get out to Bowman Lake over a rocky fire road (along with minivans and 2WD cars), and had to stop halfway because the trailer was taking such a beating.
We aren't asking this trailer to take on the Rubicon, but it would be nice to be able to explore a bit more off of the smooth roads.
Specs:
-Tandem 3,500 lb. axles, sprung-under. GVWR is 7,000 lbs
-leaf springs
-standard ST205/75D15 bias-ply trailer tires (@ 40 PSI)
-Estimated 3,000 lbs. fully loaded
Here are a few things that crossed my mind:
-Remove a leaf from each pack, or downgrade the leaf packs to make the suspension more supple. The full weight rating is not needed.
-Add shocks
What do you think?
Here's the build thread on TNTTT if you're interested.
Specs:
-leaf springs
-Add shocks
What do you think?
