John E Davies
I hope we can make this a sticky, to use as a research thread for those who are shopping for a small "sleep inside" hard sided camper.
Please don't post pics of home builds, roof top tents, or tent trailers, unless the tent trailer also has a hard sided sleeping area (eg: Tvan).
A link to the manufacturer's website would be useful if nobody has already posted it. Also indicate if the trailer is available in the USA. You can post images from other sites, but large hi-res pics that you personally took are preferred.
Thanks. JD
From Overland Expo 2012:
Track Trailers Tvan, Australia market only I think. I have been lusting after this one for about ten years.:
I don't have a large pic of the "Assymetric Link" suspension, but I found the following online. This design is used by the Australian military. Unlike a regular trailing arm independent suspension, this one maintains really good tire contact with the ground during turns when the body rolls.
http://tracktrailer.com.au/tvan/
From Overland Expo 2013:
Moby1 XTR, Utah USA. I was told that this trailer has a user added expedition rack and side rock guards. The exposed terminal strip under the center of the frame is also owner applied - all Moby 1 connections are hidden within the battery box.
The front mount looks a little light to me, but it is reinforced. The greasable Heim joint is way cool and uber strong. I would like to see some way for mud and debris to get off the suspension arms - does anyone know if there is a large opening at the rear of that flat plate? I didn't look closely there. There is an adjustable anti-roll bar to reduce the body roll that you can get with an independently suspended trailer. I don't know why the parking brake cable isn't in its bracket....
I would prefer an angled front to those forward mounts (like SoCal Teardops - see pics below) - it would deflect large immovable objects and also provide good protection from grit and water intrusion for those joints..... Plus I would rather have flush grease Zerks, not those vulnerable long ones.
This rig has no water tank - it would go behind the axle, tight up under the floor.
Note that the Heim joints are not positioned correctly - they should be symmetrical and vertical inside their brackets, not twisted. These will quickly wear grooves inside the mounts.
This early trailer has no trim along the edges of the inner wood hatch panel, as do later models.:
My wife Jac (shown above with her CaneMasters fighting cane) and I love the XTR. I especially like the extended frame ("running boards") which reinforces the fenders, so you can climb on them, and for the extra mounting space and splash protection they provide, and for their ability to deflect tree trunks or other low trail obstacles.
http://moby1trailers.com/
Here are a couple of galleries of fully equipped XTRs:
http://www.facebook.com/media/set/?set=a.588517691161142.1073741825.117644758248440&type=1
http://www.facebook.com/media/set/?set=a.595422267137351.1073741826.117644758248440&type=1
VMI Offroad XTender Compass, Washington USA:
Welded marine grade aluminum:
This one is built with rough pine. Too crude looking IMHO. Plus the hardware is marginal. Other woods are available. It has a very quiet diesel forced air furnace.
They are also developing a flip top model:
Having owned a marine grade aluminum trailer for a decade, I have to say that they keep their looks if not used when there are harsh winter deicing chemicals on the road, but the material does not flex and any un-bushed holes in the alloy can wallow out easily. Fatigue cracking is a possibility if the trailer is used hard. Maintenance is generally easy. You can polish the flat surfaces to a fierce gleam, but the diamond plate areas are sharp and will destroy your rag and fingers. Buyer beware. Aluminum is not for everybody.
This company used to build boats and has now branched off into trailers. I think there will be a steep learning curve at first, but they are worth watching.
http://www.vmioffroad.com/products/xtender-adventure-offroad-trailers.html
MORE TO COME.
John Davies
Spokane WA USA
Thanks. JD
MORE TO COME.
John Davies
Spokane WA USA
