Pugsly's FG rebuild thread
pugslyyy
THERE'S BEEN A LEAK!
I'm spending a lot of time chasing a leak at the front of the camper at the moment. I think I've got it figured out but need for the rain to stop and things to dry out before I fix it.
The floor of the bedroom and the very bottom part of the wall is wet where shown in red. Fortunately I had the mattress out of the camper so it didn't get wet.
I thought it might be the fantastic fan opening in the roof (there had been a leak there before that Doug had fixed) and I was also suspicious of these cracks in the vinyl covering the screw channel, but at the end of my investigation couldn't find any water coming down from the roof inside the walls (I pulled off the trim between the roof and wall interior panels)
That led me to the clearance lights on the front of the camper. I'm pretty sure that this is the problem. Rather than reseal the old ones I'm going to replace them with LED assemblies. I covered the openings (5 on the front) with foil tape until the weather allows me to make the fix.
I also ordered 100' of vinyl screw channel insert. I don't believe it is the cause of these problems, but it is beat up and needs replacement.
pugslyyy
MIRROR REFURB
The mirror bracketry was rusted and the plastic and vinyl were oxidized, so I decided to pull everything apart, clean/refinish the plastic/vinyl and powdercoat all of the metal bits. Also cleaned up all the nuts and bolts using the wire wheel on my bench grinder.
Since all the rub rails, etc were powder coated 'silver vein', I changed the color of the mirror bracketry from black to silver vein, and am very pleased with the results. It's amazing how much of a change $100 worth of sand blasting and powder coating will do for appearances.
At the same time, I also powdercoated the four foot cheater bar (for breaking lug nuts loose) - now instead of a rusty piece of pipe it looks intentional, and is a lot less likely to be forgotten/overlooked.
pugslyyy
CLEARANCE LIGHTS
In terms of exciting projects, this was not a high water mark. Today I replaced the 7 amber clearance lights on the Bigfoot, sealed them, and replace about 80 feet of vinyl screw cover insert.
I am hopeful that the new LED lights will eliminate the camper water leaks (or rather, the new sealant that surrounds them). The screw cover insert was cosmetic / prophylactic - and quite a lot of work. I still have the driver side to replace, but have the top and passenger side completed.
pugslyyy
Does it mean that you are going nuts? ;)
Hey, I bought 2 Fusos within 4 days - I think that bridge has already been crossed.
Actually, after sitting in my driveway for a couple of months the green crew cab is scheduled to head out next week for test fitting of the new front axle...
blackduck
Exactly! These are the lug nuts for the SRW conversion.
Correct me if Im wrong (Alan)
but they look like wheel nuts that would normally fit on the front hubs
when I fitted bling wheels to get thread depth I had to fit the square head lug nuts that would normally hold the rear inners on straight onto the front wheel studs and then use rear wheel nuts to hold the bling wheels on
this is what arrived in the post for me
pugslyyy
OK so you putting on Johns blingy ATW wheels
not Alans blingy aluminium wheels
you got me all confused for a moment
Yeah, for my weight it was the only real option I ended up being comfortable with. Sorry to confuse - when I said yes I meant yes to "SRW" not "Alan's SRW", my bad.
