Handling problem - Help!
ianc
Adventurer Wannabe
I'm posting a new thread on this because it’s a specific issue I'm looking for advice on.
My project van is (sort of) well documented on this thread http://www.expeditionportal.com/forum/threads/78237-Pre-birth-of-a-camper-No-laughing
It's now largely finished but I'm having a handling problem that I can't figure out.
The Symptom:
If you make moderate steering adjustments at speed (>60kph) the tail feels like it's coming around and causing the van to overseer which then has to be corrected quite quickly. It feels like the tail would easily come around and a bit scary. Interesting thing is though, if you're on a twisty road and having to make significant steering adjustments then the problem is not really noticeable even at dizzy speeds up to 80+kph.
This has been brought to a head because the guy who's doing the engine re-mapping made similar (more colourful) comments.
The Facts:
The base van is a Mercedes 814DA 4x4 chassis. It recently went through a reasonably comprehensive DoE test so suspension joints, bushes, ball joints etc. are in good shape although I do think the shocks are tired.
It originally came with 17.5" wheels with Michelin 9.5 R17.5 XZT tyres and dual wheel set-up on the back. I've since fitted 19.5" "Super Single" wheels from Aspect fitted with 285/70 R 19.5 Continental HDR tyres. I believe its fitted with the heavy duty version of the anti-roll bar - but I need to check this.
Wheelbase is 3.7m, rear overhang is 2.1m and its 3.5m high and 2.3m wide, overall length is about 7m. Distance between the outer walls of the rear wheels is 2200mm. Box construction is fairly standard 2mm GRP, 4mm ply, 50mm dense foam and 2mm GRP. There are 2 baffled water tanks of about 250L each mounted in the box (effectively on top of the chassis rails) and just behind the rear axle line. Most tests were done with these full or nearly full.
The axle loads are 2500kg on the front (max is 2800kg) and 3300kg at the back (max is 5500kg). So loaded weight is 5800kg on a 7500kg rated chassis. There is comfortably 100mm of travel left in the rear suspension before it even begins to touch the bump stops and the stops have a lot of give in them. The front it much closer with only about 45mm travel left. But I've checked this and any other 814DA I've looked at has similar limited front end travel. It does easily bottom out at the front when on bad roads - but the "symptom" is most evident on smooth roads.
I've had a friend who's a trained car mechanic followed me while I navigated some roundabouts and other corners and he felt it was not leaning much - no more than other commercial vehicles.
I think I'll get the shocks replaced anyway. Any suggestions on what to upgrade them to or who I should talk to in UK, Ireland or Northern EU?
I'm wondering if the single tyre on the back has more tyre wall movement than the original setup? Although the walls in the HDR tyres are shorter and much heavier than the XZTs.
Thoughts, Suggestions?
canals1164
Low tyre pressure perhaps? We have fitted large super singles to replace twins on our larger truck, whilst the ride quality is a lot better on the straights the price seems to be a slight boat like handling issue on the corners.
ianc
Adventurer Wannabe
I'm running 100psi in the back and was at 100 in the front but have dropped to 85. The drop in the front seemed to help a little.
Alastair D(Aus)
aging but active
try the duals
Ianc,
I would guess it is due to the tyre change. Do not know the Continentals but perhaps the side wall flex is causing the issue.
If you still have the original wheels I would put them on for a trial, the rear duals at least. This will quickly tell you if it is a mechanical problem.
cheers
NigelEvans
Ian,
Don't know if you saw it but I posted what sounds like the same problem with my truck after the single wheel conversion. I was unable to resolve the issue and after a few thousand miles just got used to it (or it got better). I did take it to an old airfield and threw it around a bit without getting into any major problems so I decided it was safe to drive. My experience with new motorcycle rubber is that it sometimes feels squirmy at the back end until you've done a few miles - Could this be an issue?
Your tyres (like mine) are designed for traction axles not steering; I did wonder at the time if this might be an issue.
I had a brief look at the data sheet for your tyres; are your inflation rates high? A call to their technical support team couldn't hurt.
You're welcome to take mine out for a run to compare (Malvern?).
ianc
Adventurer Wannabe
Nigel - Will you be at the AO show in a few weeks? Is that Malvern- I thought it was Stratford? It would be great to compare notes and I'd love to take you up on the offer of a spin.
The tyres should be able to comfortably carry the rear axle load at <85psi - so the inflation rates are high. I kept them high because I felt that this reduced sidewall flex. I'll give the tech support line a call.
NigelEvans
Quite right, Stratford Racecourse, I'll be there.
I think it's important to get the pressures right and to make sure you're mechanically sound. However, in the end I do think this could be a characteristic of driving a HGV with a fairly high centre of gravity that you'll get used to (or won't notice).
By the by I did check on the Uli site and they were all getting very similar MPG to me. Hopefully your ECU reprogramme will sort this out.
ianc
Adventurer Wannabe
Just got off the phone with Continental Tech support in the UK. Very helpful. He told me that
a) my pressures were waaay too high and to come down to about 65psi front & back and certainly no more than 73psi.
b) moving to single wheel on the back will change the characteristics because the contact patch is effectively reduced
Nigel - How do those pressures compare to yours?
I have a 80km journey to do tomorrow evening. So I'll adjust down and see how it goes.
Then I'll try going back to the Duals - just as a process of elimination as per Alastair's suggestion
Dragonsmaug
Ian you could also try it under different ballast conditions , for instance load up the box with bags of sand or drums of water at the front and separately try with more weight at the rear or without water in your tanks,I have found mine feels better to drive with the front axle fully loaded and moved weight from the back to the front to achieve this.Chris
ianc
Adventurer Wannabe
Dragonsmaug,
Yes roll bars front and rear. I found out yesterday that are different thicknesses available (46mm & 50mm). I'm not sure which is on mine but I will check. The van is "away" at the moment.
I just noticed on another posting that you have helper airbags in the front. Where did you source them and hhow did you fit them. Some photos would be really appreciated.
Dragonsmaug
The airbags were supplied and fitted by Matt Savage and are of american manufacture easy to fit due to plenty of room but require solid location on the upper spring leaf. I think and stress think that they act as extra damping on the front axle as well as the obvious advantages of giving adjustable axle movement and leveling when parked and on the move, I tried and failed fitting personally smaller air bags on the rear axle due to the limited space over the rear springs.I will try and post photos
Chris
ianc
Adventurer Wannabe
I was considering a bag which would replace the standard bump stops on the rear. I never got to fully research it though. Pics would be great - along with a rough measure of the bag. BTW most airbags that are sold in the US seem to come from this company http://www.driveriteair.com/en in Dublin!!
ianc
Adventurer Wannabe
So there's good news and a fair bit of less good news...
Good stuff first. Dropping the tyre pressures made a big difference to the handling. It's still a little floaty at the back but not a worry any more and the ride is much improved as well. Not a surprise having found out I'd over inflated by about 80%!
Also the re-mapping guy got the map done and said it was now pulling hard even in 5th! Hooray!!!!
Not so good stuff:
- The mapper guy could not get the map permanently uploaded to the ECU. I'm going to have to take the ECU out and either bring it to a guy in Belfast or post it to another specialist in the UK :(
- Mapper guy also said that the left front brake calliper was not working properly and he's correct - it's pulling to the right. Hopefully just a cleaning job. I profoundly hate cleaning brake callipers
- I also regularly checked the tyre temp on the way home this evening. Just in case.... and found that the rear passenger hub was getting too hot. So I probably have a binding brake. :( Argh! Another one to try to clean.
Also I'm pretty confident I will still need to replace the shocks. I've tried Koni and they do not appear to have options. Any suggestions?
