richard310
pew pew
Updated as of January 14, 2016
Hi guys. Been a long time lurker here for a few years and finally found what I've been looking for after 6 months of searching.
2004 Xterra XE (D22)
4x4 Automatic
KY2 Pewter Metallic
Engine/Transmission:
- Nismo SS Catback Exhaust
- Nismo K&N Cone Filter (removed and swapped for OEM air box)
- NGK Spark Plug Wires
- Mean Green 180A Alternator
- Supercharged Xterra Radiator
Major Maintenance:
- Timing, A/C, Alternator, Waterpump, Power Steering Belt (11/2013)
- Spark Plugs/Distributor Cap (11/2013)
- Water Pump, Thermostat (11/2013)
- Crankshaft/Camshaft Seals (11/2013)
- Replaced Leaking High Side A/C Line (6/2014)
- Replaced Driverside Axle (8/2014)
- Replaced Starter with Ultima Remanufactured Starter (8/2014)
- Replaced alternator with rebuilt OEM 100A unit (12/2014)
- Rebuilt Alternator took a dump, modified pulley and installed Mean Green 180A Alternator (2/2015)
- Condenser to Compressor line replaced (2/2015)
- Front and rear diff fluid drain & fill (2/2015)
- Induction Service (TB Clean, Manifold clean, everything pre-engine was taken apart and cleaned) (2/2015)
- Replaced LCA balljoints, steering tie rod ends and balljoints: PRICEY! (3/2015)
- Replaced Calmini UCA balljoints (3/2015)
- Replaced leaking radiator with Supercharged version (6/2015)
- Replaced AC Pulley Tensioner
Tires:
- Cooper ST Maxx Load Range E, 265/75-16 (32")
- (REMOVED) BFG AT KO's Load Range E, 265-75-16
- (REMOVED) General Grabber stock spare
Suspension/Brakes:
- Bilstein HD 4600 for 3inch lift
- 4x4Parts Front Sway Bar Polyurethane Bushings
- 4x4Parts Front Sway Bar Polyurethane Endlink Bushings
- 4x4Parts Rear 3-leaf AAL
- Calmini Extended U-Bolts and Hardware
- Calmini HD Upper Control Arms and Ball Joints
- Calmini Idler Arm Brace
- Firestone Lifetime Alignment
- Powerstop Slotted and Crossdrilled Rotors
- Powerstop Scorched Evolution Pads
- Raybestos Rear Drum kit
- (REMOVED) Pro Comp ES9000 Shocks
- (REMOVED) Bilstein Rear 4600 OEM Shocks
Exterior/Armor:
- Trekking OASIS II Tent mounted on OEM roof rack
- Calmini modified rear dual swing out tire carrier
- A/T NATO double can holders
- Front Runner roof mounted double NATO can holder with custom mount
- Deustcheoptik NATO 5gal/20L jerry cans
- Hi-Lift 48" Jack
- ARB 1250mm Awning
- ARB 1250 Awning Front Wind Dam
- White Knuckle Sliders
- Xoskel Light Cage
- Nokya Arctic Yellow 9007 Headlight bulbs
- BlitzPro 6LZ 6" Roof Rack Lighting
- Generic 32.5" 180W Combo LED Bar
- Generic 6.8" 30W Combo LED Bar
- (REMOVED) Rugged Ridge 6" lights with 3000k HIDs
- (REMOVED) Tuff Stuff 4.5" HID 6000k
- (REMOVED) Hella Rallye 1000 Black Magic 55W Lights mounted on stock bumper reinforcement with Nokya Yellow H2 Bulbs
- (REMOVED) 32" LED Light Bar 18,800 Lumens mounted on Xoskel Cage
Comms/Electronics/Interior:
- Mob Armor phone mount
- Custom rear cargo system
- Midland 1001LWX with NOAA CB Radio
- Firestik SS204A Mount
- Firestik II 3' CB Antenna
- Kenwood TM-281A 65W 2m Radio
- Diamond K400S Mount
- Diamond NR770HB Antenna
- Lowrance GlobalMap Baja 480c GPS with RAM mount
- Red LED Dome lights
- DepHep Rear Window MOLLE Panels
Recovery Gear:
- TRED 1100 (2)
- ARB Speedy Puncture Repair Kit
- ARB 8000kg Snatch Strap
- 7/8" Shackles
- MV50 Compressor
- Tow Strap
- Ace Hardware Shovel
How it sits today:
When I first picked up the rig:
4x4 Automatic
KY2 Pewter Metallic
Major Maintenance:
Tires:
Suspension/Brakes:
Exterior/Armor:
- Hi-Lift 48" Jack
- ARB 1250mm Awning
- Xoskel Light Cage
Recovery Gear:
- TRED 1100 (2)
- 7/8" Shackles
- MV50 Compressor
- Tow Strap
How it sits today:
