offroadtreks
Deplorable
2003 TRAILBLAZER LTZ - FAMILY ADVENTURE MOBILE
The goal of our Trailblazer is to support our family of 3 and one dog on cross country road trips and multi-day off-road expeditions. Because we love to travel we are seeking a compromise between an off road capable trail rig and the perfect vehicle for road trips. We're currently experimenting with a more aggressive tire setup, but will be making a large trip this Aug back out west.
**You'll notice in this thread the use of Phase 0 & Phase 1. Phase 0 is everything we did in 2012, essentially all our first mods, a trial and error phase. We also tested all of the Phase 0 mods in Moab, Utah. Phase 1 is everything we have done in 2013 based on experiences learned in 2013 during our trips & expeditions. Phase 2 mods are our latest mods based on our newest goals and plans for the truck.
Where it stands today: [Updated 01/24/14]
**I've included links to either the products themselves or to relevant threads for each mod
SUSPENSION / AXLE:
ENGINE / DRIVETRAIN:
VEHICLE ARMOR:
ELECTRICAL / LIGHTING
EXTERIOR APPEARANCE:
INTERIOR MODIFICATIONS:
RECOVERY & EMERGENCY GEAR:
PLANNED MODS
SUSPENSION / AXLE:
- 315 / 70 / R17 - Nitto Trail Grappler M/T
- The Lift Miester 1.5" Adapters 6x5 on 6x5.5
- The Lift Miester 3" body lift
Front - Radflo Custom Coilovers (Adjusted to 3.5inches of lift)
- Flipped Upper Control Arm
- Suspension Maxx Sway Bar EndLinks
- Fabtech 2500 HD Tie Rod Ends (Inner & Outter) Part #FTS71002
Rear - 2" BDS Suspension Coil Spacer
- Tahoe Z71 Rear Springs Part #15234633
- BDS Rear Shocks Part #55619
- Rear Sway Bar Deleted
- Massive Adjustable Upper Control Arms
- Massive Adjustable Lower Control Arms
- Massive Adjustable Panhard Bar
- Volant cold air intake
- Resonator Delete
- Transmission Rebuilt 1/23/13
- Corvette Servo
- Sonnax Transmission 4th Gear Billet Super Overdrive Gear
- Transgo Stage 2 Shift Kit
- Trailblazer SS Torque Converter
- Beast Carbon Sunshell
- Carbon Clutch Kit
- B&M Super Cooler Transmission Cooler
- Amsoil Synthetic Motor Oil - Dif Oil - Transmission Oil
- Trailblazer EXT/SS Brake Upgrade
- Power Stop Zinc Coated Cross-drilled & Slotted rotors with Carbon Ceramic pads
VEHICLE ARMOR:
- Spider Differential Rock Guard - By Purple Cranium
- MDB Oil Pan Skid Plate
- MDB Radiator Skid Plate
- Eagle Eye CCFL Halo Projectors
- DDM Tunning HID low beams 55w at 5000K
- DDM Tunning HID high beams 55w at 5000K
- Eagle Eye LED rear tail lights
- Dual brake light/blinker mod
- 4' Firestick Firefly CB Antenna mounted using FireStik MK-J4R Jeep Mount
- Cobra 18WXSTII
- x2 Hella 500FF Driving Lamps (round) mounted on custom front bumper mount
- x4 Roof Top Hella 550 Driving Lamps
- DieHard Platinum P-4 Battery
- Method Race Rims Double Standard Matte Black
- Baja mule rack
- Debadged Rear Deck
- Demolded the side doors
- 20% tint all around
- Shortened radio antennae
- Silverado Tow Mirrors (Heated, Power with LED turn signals)
- Rear Seat Delete
- Removed cargo area carpet and plastic molding
- Rhino lined cargo area
- Custom storage area
- 60" Hi-Lift Jack All-Cast in Red
- 30' ARB Recovery Strap
- ARB Tree Saver Strap
- x2 50' Steel Tow Cables
- x2 ARB D-Ring Shackles
- Fire Extinguisher
- Road Flares
- ARB Tire Repair Kit
PLANNED MODS
- Custom Rock Sliders - Currently in fabrication
- 8.6 rear axle swap
- 4.56 gears
- Aftermarket locker
- Fabtech FTS81026 rear shocks travel, extended length 27.56" and compressed length 17.52"
- Custom front bumper
- 250 Amp High Output Alternator
- Darale Performance High CFM daul radiator fan & shurd
- Griffin Aluminum Dodge Charger Radiator Upgrade
- B&M Deep Transmission Pan
- 6AN Transmission lines
- Recovery Winch
- Off-road / Bug out trailer
