FM82 Offroad Teardrop Build
Well, my shadetree jig was a flop. The tubing bent, but also twisted. Tried a hydraulic bender that just kinks it. Now to check with a local metal worker to see if they will heat it and make the bends for me.
Sent from my XT1030 using Tapatalk
dcollier32
I'm assumeing you are using square tubing? But a true metal shop should have a mandrel bender. It stretches the metal as it is bent, so there isnt any creases in it...
Well hopefully this guy will have the goods to do it. Without a torch to heat it...I think I've been defeated on this one.
skersfan
Supporting Sponsor
If all else fails, you can lay the metal flat, and make cuts at about 3/4 inch and slowly bend to what you want. then make a L under it to solidfy it. tack weld each cut. That area is normaly not under stress. I still think a dune buggy shop should have the bender, you may have to by the dye for 1 inch square. Normally costs about 150.00 for it. I had Poison Spyder do my last bows for my rear door. Any jeep accessory businesses located in Florida?
I have a question for those that have "been there done that". How much cabin ventilation do I really need? Is an RV roof vent necessary for a teardrop? Or would I be just fine with a vent that measures ~4"x12"? Trying to conserve roof space...
Oh yeah, I did check with the one of the buggy guys and he has his brother do his work for him. Haven't been able to talk with his brother yet. I did think about cutting it. It may be the same thing you're talking about. What I was thinking about was making relief cuts down the length of the tube and weld them back in after I get the shape I need.
Absolutely. Most of all though is...I have a hard time with not doing it myself. Even if it takes screwing up 4 or uhhh 40 times or so lol.
Way Down South
Got my siding in today! I sure hope this bends like the picture shows lol.
Hi, if this is the stuff that is aluminium on both sides and a poly core you can also score and snap your straight lines. Say you want to cut it to length put a straight edge across the sheet, score once with a box cutter, flip and snap it up. Then run the box cutter on the other side and off it comes.
Yes it is. That's good to know that I won't have to break out a saw every time I need to make a cut.
dcollier32
How much was that sheet? Also, where did you get it? I might need to know, incase I decide to build another trailer
Actually, I lucked up and got it at a wholesale price locally from a friend who owns a sign/vinyl shop. I gave $55 per sheet. I looked it up online and couldn't seem to find anyone that I could get it from.
I take that back. I think I did find one place, but it was in the $200.00+ range per sheet...IF you buy 5 or less :/
