StarkPower’s “ULTRASTART” has the same features (cell balancing) as the “ULTRA” but with additional features. StarkPower’s “ULTRASTART” has a processor controlled Battery Management System (BMS) inside each case to monitor each cell to prevent over charging, over discharging (voltage draining too low) along with cell temperature monitoring. Should any of the cells reach outside of its allowable specifications, the terminal power will turn off. These are added performance and convenience features to prevent a battery from being damaged or in the event a battery is left unattended for a long time. These added features also prevent the battery from over-charging when attached to other charging equipment or charging failure. In the event a lower cut-off voltage is reach, the battery terminals will have 0V on them.
The battery needs to be “kick started” with a charger (using a StarkPower charger) that has a battery voltage on the terminals. That will turn ON the battery again and start taking a charge. Some charges need to sense the battery voltage first, thus will not turn on or take a charge. In the event over-charging condition is reached, the battery terminals will have 0V. Turning off the charger and letting the battery rest a couple minutes should allow the battery to turn ON again and operate.
In the “ULTRASTART” models, the processor controlled Battery Management System (BMS) has the ability to provide reserve engine start-up power when needed. At motorcycle rallies or gatherings, owners of heavily accessorized motorcycle often want to keep their radios or lights on when parked, possibly draining standard lead-acid batteries too much. The “ULTRASTART” automatically senses excess drainage status, shutting all accessories off, while maintaining sufficient reserve power to start the engine. This is known as StarkPower’s “IQ RESTART TECHNOLOGY”- Adequate reserve power is left in the battery, to automatically detect starting effort with a key cycle and allows users to start the engine again and not leaving you stranded or with the headache of calling for service or even needing to replace the battery. A significant advantage of the ‘ULTRASTART” technology and a major selling point is the “IQ Restart Technology”.
