fast_suv
I did get this Trailer as you will read later in the post; But on a side note, If anyone has one of these or any information on them i would love to talk. I really would like to know more about their short lived history....
So as I was searching for an rtt for a utility trailer build up I stumbled upon this rough out products pop up for sale:
I'm thinking about picking it up if we can work out a reasonable deal.
My one concern is that the owner never titled it and the company has gone out of business.
The is currently no Vin plates or anything like that one it, it was sold as an off road camper from the company.
I'm in VA and can get a Vin for it and title it as a homebuilt trailer.
My question is on the form it has a place you can check that states: if you were not involve with the construction of the trailer put the name and address of the person that was.
Now I don't mind taking it apart and rebuilding it so I can say I built it but that may take a week or two... If i put rough out products info on there and they are no longer in business will dmv try to contact them?
Thanks for any input
*******UPDATE*********
So i figured i would update the first post from time to time to make things easier to look at....
Plans:
short term:
weld in 2" reciever for Lock n Roll hitch √
Clean up √
New bed/mattress√ (just cleaned up the existing
New Velcro and other hardware √
run new wiring
fix door fiber glass √
run new water lines √
check propane line (replace if needed)√
replace top sides
hi-lift jack mount
Licens plate mount
Interior LED lighting
Solar panels √
wire in inverter and run plugs√
Re coat frame √
Long term:
New cook top
new hubs and or axle set up
paint to match JK
Jerry can mount√ (in process)
Fan install
removable AC install for park camping
4.5lb propane tank mount
propane furnace
low draw fridge
ect.....ect..... ect....
Current status Picture:
Plans:
short term:
Clean up √
run new wiring
replace top sides
hi-lift jack mount
Licens plate mount
Solar panels √
Re coat frame √
Long term:
New cook top
paint to match JK
Fan install
propane furnace
low draw fridge
