Summit Cruisers Jr
First post here. I figured I would share with the ExPo crowd. I will update this thread with more as I have time to. I will be posting quite a lot of photos to show its progression over the past 4 or so years.
Edit: Here is the most complete mod list I could come up with, but I am sure I am missing other small things. (Updated 9/16/18)
Aesthetics
Full Custom Paint Job Inside and Out (FJ40 Dune Beige, with matte black on hood, bed liner on flares-rockers-rear cross member-rear hatch wind deflector, gloss black around windows, VHT Graphite Gray on wheels-misc. trim, and satin black mirrors-door handles-door stripe)
95-97 Grille Conversion
XPEL Paint Protection Film on the Hood
3M Paint Protection Film on Lower Rear Doors
15% Window Tint
Cloth Interior Redone to Leather
Color Matching (Tan 17) Wet Okole Seat Covers w/ 1" Padding Underneath (Front) Replaced by Charcoal Wet Okoles with Lumbar and Front Pockets
Black Zebra Wood Interior Trim
Retro "TOYOTA" and "4WD" Decals on Tailgate
TRD Decals on Rear Quarter Panels
License Plate Relocated to Passenger Side
TRD License Plate Frame
Rear Hatch Wind Deflector
Stickers
JDM 80 Series License Plate Lamp Assembly
Bumpers, Armor, and Recovery
Ironman 4x4 Deluxe Bull bar
Custom Built Rock Sliders
Gray Industries GIS Crossmember/transfer case skid
Custom Driver's Side Tire Swing Out
Custom Passenger Side Cooler (Yeti 45) Swing Out
12,000 lb Badlands winch w/ ARB 4x4 Accessories
48" Hi-Lift Jack w/ Custom Dune Beige Handle
Hi-Lift Bull Bar Mounts
Factory Rear Crossmember Replaced by 2x4x1/4" and set up with a Custom Receiver Hitch
OEM Tow Hooks Front/Rear
TredPro 4x4 Recovery Mats
Suspension
Ironman 4x4 Performance 50mm Coils
OME Nitrocharger Sport L Shocks
OME Steering Stabilizer
Custom 1 3/8" Front Coil Spacers
Air Lift 1000 Kit in Rear Coils
15mm MetalTech Leveling Spacer on driver's rear coil
Washer Mod Castor Correction
Custom Sway Bar Drop Brackets
Rear Bump Stops Lowered 1"
Extended Brake Lines
Blackhawk HD Lower Control Arms
Blackhawk Adjustable Upper Control Arms
Tires, Wheels, Axles, and Differentials
35x12.5r17 Kenda Klever Mud Terrains Replaced by Yokohama Geolandar MT G003 in August 2018
2011-2014 FJ Cruiser/2010-2013 4Runner Trail Edition Wheels
Internally Ground Down Center Caps
Nitro Gear and Axle 4.88 Ring and Pinion (Front and Rear)
Harrop E Locker (Rear)
Full Float Rear Axle Swap
Heavily Modified Moto Farkles R Diff Armor
Cruiser Outfitters HD Part Time Hubs (Spool hasn’t been installed yet)
Roof Rack, Roof Top Tent, and Awning
Custom Built Full Length Flat Rack
CVT Mt. Bachelor Roof Top Tent and Annex
Custom Wind Fairing for RTT
Custom 8ft Awning
Head Unit, Speakers, Cameras
Pioneer DDX470 Head Unit
USB/AUX Port in Center Console
Kicker KS40s For Dash Speakers
Four Kicker KS65 Speakers with Custom Front Door Speaker Holders
Kicker 10CVT654 Shallow Mount Subwoofer ----replaced by a Pyle
Esky Reverse Camera
Front Camera
Kicker KX400.4 Amp for KS65s
Kicker CX300.1 Amp for 10CVT654
Kicker Fuse Block
Kicker Power Distribution Block
On Board Air System
Custom York 210 On Board Air Compressor
Air Outlet in Front Bumper
Air Outlet in Rear
Air Horns
5 Gallon Air Tank
Custom Rear Air Tank Mounts
Cooling/Performance
Grand Prix GTP Hood Vents
Aluminum radiator - Replaced in August 2018
Electric Pusher Fan
Green Hub Fan Clutch w/ 15k CST Fluid
Osidetiger 4-Hole Fuel Injectors
NGK Iridium Spark Plugs
EGR Delete
High Clearance Cat-Back Exhaust with Single Cat Conversion
EFI Relay Relocated to Driver's Kick Panel
Snorkel
Stoptech "FZJ sized" Slotted Front Brake Rotors
FZJ Front Brake Calipers
Powerstop Carbon Ceramic 100 Series Pads (front)
StopTech Slotted FZJ80 Rear Brake Rotors
Powerstop Carbon Ceramic Rear Pads
Lighting
Custom Euro-Spec Depo Headlight Conversion
Slee Offroad Headlight Wiring Harness
40" 6D LED Light Bar on Roof Rack with Custom Mounts
Two 4" LED Light Bars (Rear)
LED Interior Lighting
LED Reverse Lights
LightForce 240s w/ Amber Combo Filters
Depo Valence Lights
Fog Lights in Ironman Bumper
Tinted LED Brake/Turn/Running Lights in Rear Bumper Wings
Blue Sea Contura 6 Gang Rocker Switch Panel
Daystar Rocker Switches (Labeled)
Custom RTT LED Lights
Storage
Custom Rear Storage Box --Removed
Rear "Attic" Storage Rack
Custom "Tuffy Style" Center Console
Custom Rear Drawers With 36" Accuride 9308 and 9301 Slides
Custom Fridge slide for 63qt ARB Fridge
Wagongear Tailgate Lid
Creature Comforts and Miscellaneous
Northshore NSR-4 Bike Rack
Custom 2-Bike Tray Rack that mounts to cooler swing out
ARB 63qt Fridge
Custom Drop Down Table on Cooler Swing Out
Custom Ram Mount From Grab Handle for Garmin ETrex
Midland Handheld CB Radio
4' Firestik Antenna
Trasharoo
Pin 7 Mod
OEM Passenger Dash Grab Handle
Keyless Entey
TRD Seat Belt Pads
Strong Arm Hatch Struts
Land Rover Cup Holder Mod
Third Row Cup Holders
Dual Fold Out Cup Holder on the back of the Center Console
Dual USB Outlet on Console
12v Outlet on Console
Extended Differential Breathers
Custom Driver's Seat Extension Brackets
Third Row 12V Outlets
Seat Recline Mod (2nd and 3rd Rows)
Dorman Front Window Track/Motor Assemblies
Anyways, this is how my 1992 Land Cruiser looked when I first inherited it at 16 with 310,000 miles. This was the car that took me to preschool, elementary school, middle school, and some of high school. My parents purchased it back in the early 2000s with 175,000 miles on it. As far back as I can remember, I remember this car. My family would always take it to Colorado in the summers and explore the alpine roads. My dad has always been meticulous when it comes to maintenance. It is still on the original head gasket, transmission, transfer case.
Just before I inherited it, the build started. In an effort to get rid of the "mom-mobile" look, my dad and I painted the wheels with a VHT wheel paint, added an Ironman Nitro Gas 2" lift with 1 1/4" spacers on the front to level the ride height, had the windows tinted, and added 33x10.5x15 BFG KM1s.
With the Colorado trip around the corner, we pulled off the damage multiplier on the front, took off the running boards, painted the grille/headlight trim/bumper trim to match the gray wheels, and painted the flares and bumpers in Rustoleum bed liner to see how it would hold up.
After returning home from Colorado and passing my driving test in the 80, it was time for fresh paint. My dad and I had always planned to repaint it to something more retro and unique. He had some left over FJ40 Dune Beige from a restoration he had done on one of his 40s. It was decided that it would become that color with many black accents.
Aesthetics
15% Window Tint
Stickers
Suspension
Custom 8ft Awning
Esky Reverse Camera
Front Camera
Kicker Fuse Block
On Board Air System
Air Outlet in Rear
Air Horns
5 Gallon Air Tank
Cooling/Performance
Electric Pusher Fan
EGR Delete
Snorkel
Lighting
LED Reverse Lights
Depo Valence Lights
Storage
ARB 63qt Fridge
4' Firestik Antenna
Trasharoo
Pin 7 Mod
Keyless Entey
TRD Seat Belt Pads
