Todd McLaughlin
Next was the clutch pedal setup, after removing the old automatic brake pedal set, I searched the US for about 4 months trying to find a hydro clutch system, to now avail I failed in my hunt. Frustrated I returned to the donor truck I found the hydro boost brake system and removed the manual pedal setup. Knowing the hydro boost came from this vehicle I had no trouble with brake pedal push rod alignment. The clutch pedal was a total different story. With some basic welding skills and a little luck this is what I came up with.
This is the brake pedal and the clutch pedal dis-assembled.
After a few re-installs I checked the clutch alignment and started the modifications, I installed the clutch master cylinder in the manual speedometer cable hole the alignment worked great.
