Johnnyenglish
After a couple years of working slowly but surely on my build, things have finally kicked into high gear! I'm not really a rock crawling type of guy - more overland trips in the southwest. Up to this point I've installed the following mods:
After 2 years I had gotten this far:
I was planning on waiting until I was out of warranty to pull the trigger on a suspension lift, however, after doing a bunch of research on this forum and the AEV forum I decided to go with a dealer installed (and dealer warrantied) AEV 2.5" Dual Sport lift with geometry correction/pro cal on BFG T/A KO 315/70 17 and matte black AEV Savegre wheels. I'm adding the AEV tire carrier as well. I decided on sticking with a 2.5" lift because this is my daily driver as well. My initial questions for the group are:
- DBox5 relay
- Hella Rallye A Pillar lights (removed after installing the BajaRack due to conflict)
- LED bumper flood spot/combo
- COBRA 75 CB
- Hood mounted Hi Lift
- Daystar lower dash switch panel
- Garvin Trail Rack with Rotopax Gas and water
- BajaRack Exp roof rack
- ARB Outback Solutions roller drawer
- Am I missing any mods that make sense to do at the same time?
- Will I be happy with the BFG T/A KO? What other choices are out there in 35" tires?
- I have 4.10 gearing - I've seen conflicting opinions on whether I should re-gear. What are the latest greatest thoughts on this topic?
- Is the AEV fuel caddy worth $350?
- Any recommendations on RTT? I'm in San Diego and most trips are in the southwest so extreme weather isn't a big issue.
- Any other overlanding specific mods I should be considering?
