ColoDisco
After reaching our last campsite and finding all our headlamps and lantern were without power I decided the RTT and awning needed some lighting. Hit Amazon and bought a couple rolls of weatherproof LED lights, some connectors so I could connect multiple strips together. Also added a new fuse block to separate out the power to the tent. Also because the default for this setup is on. In other words if the lose power they automatically turn on when power is restored. This is a problem as you will not know they are on and they can drain your battery. For now I just pull the fuse until we reach camp. Plan on putting the power supply on a switch.
Here is what I bought:
LED lights, cool white for the awning area and in the tent. Warm white for the annex area.
LEDwholesalers 16.4 Feet 300xSMD3528 LED Flexible Strip with Waterproof Sleeve LED Ribbon 5 Meter Reel 12 Volt, White 2047WH https://www.amazon.com/dp/B003G9408K/ref=cm_sw_r_awd_Lhxtub0HW9CT1
LE Lampux 12V Flexible Waterproof LED Strip Lights, Warm White, 150 Units 5050 LEDs, Light Strips, Pack of 5M https://www.amazon.com/dp/B00JQV6S96/ref=cm_sw_r_awd_Ynxtub17P8P46
Bought these switches to allow us to dim the lights and turn the off individually.
Globle New LED Dimmer Controller 12V Switch ON/OFF LED Strip Light Dimmer Controller Multi Mode https://www.amazon.com/dp/B00HTXICGK/ref=cm_sw_r_awd_Gpxtub1F6EBM9
And these to tie them together or start new connections.
Estone 10pcs Connector Adapter Cable LED PCB Strip 3528 to 3528 Single Color 8mm Free Welding https://www.amazon.com/dp/B00GTGLCXI/ref=cm_sw_r_awd_Lqxtub15V8Z9C
ZITRADES 8mm 2Pin 10Pcs LED Strip Connectors For 3528 Single Color LED Strip BY ZITRADES https://www.amazon.com/dp/B00B98ZUBG/ref=cm_sw_r_awd_ysxtub0S3T4MA
Bought this wire to run power.
20m 66ft 20awg Extension Cable Wire Cord for Led Strips Single Colour 3528 5050 https://www.amazon.com/dp/B009VCZ4V8/ref=cm_sw_r_awd_Hrxtub0KDBVT5
Fuse block:
Awning lighting:
Tent lighting:
Annex lighting. Still need to do the finishing touches on securing the wiring.
Please share any of your solutions to lighting!
Fuse block:
Awning lighting:
Tent lighting:
