Solar Generator (DIY Goal Zero Yeti)
Javelinadave
My daughter is an insulin dependent (type 1) diabetic which lead me to build this project. If her insulin gets warm it stops working so I needed something to power an ARB 12v refrigerator if we have a prolonged power outage at home. It will also work as a power station for base camping trips. In a nut shell it's a Goal Zero Yeti 1250 for less than a third of the cost. I thought I would share it if anybody else is looking to build something like this or for any diabetics that have wondered what they would do if the power went out in the summer time for an extended period of time.
Here is the breakdown. I purchased these three dustproof containers at Home Depot ($98 OTD special) I only used the bottom wheeled box which by itself was $60.
Next up was selecting the battery. I wanted something sealed so I went with a 70ah AGM battery from Auto Zone. I considered Optima but from my research the new ones lack quality and were WAY more expensive. The charge controller is a Morningstar 10amp model from Amazon ($56).
I went with Blue Sea for the fuse panel, master switch, 12v outlets and the USB outlet. Amazon had them but they were about 10% cheaper from a marine shop on EBay.
Here is the almost completed interior. I still need to cut some stiff foam to hold the battery in place.
The RENOGY 100 Watt 12v solar panel was purchased from Amazon for $150. I also bought with it a 25 foot cord and cut it in half so I could have a positive and negative 12" section with the correct connectors for the panel. On the box side I went with an easier to connect/disconnect plug type.
All the wiring is 10 gauge except for the wiring to the USB. Goal Zero wanted about $1600 for their unit plus a few hundred for the solar panel. I'm in it for less than $500 and am very happy with the final results. The rolling box weighs about 50 pounds and the panel weighs just a few pounds. I still need to make some folding legs for the panel and sew up a neoprene sleeve to store it in.
AndrewP
You did well with quality parts and neat wiring. It looks like you can expand to a second battery if desired, but you can run an ARB fridge for several days with that set up.
You might consider adding a "shore charger"- like a battery minder, to keep it topped up at all times.
How is the battery secured inside the box?
Javelinadave
Thanks. As a former helo mechanic I can't stand wire "birds nests". I also have a battery tender hooked up but not pictured. The battery will be held in place with stiff foam blocks. I will hunting them down this week.
JMarcPeters
Very nice. Thank you for sharing. I too was just looking at Goal Zero just today. Yours is very sweet and very doable.
Javelinadave
Inverters have a huge appetite for power so probably not. I have a Honda EU2000 generator if I needed to power anything 110v A/C.
gkcarmory
Nice!!! Actually looking at the Goal Zero at a local store the other day... Great write-up
cottonwood
Another T1D parent here, very nice set up! We've been looking at options & this is great. Camped this weekend and drained all my juice charging Dexcom share & his phone. The ability to run a cooler would be great.
Javelinadave
The experiment starts this morning and this should be a good test. Today's forecasted high...... 113F (45C) with an evening low of 85F (29C)
calicamper
What sort of output are you seeing from the panel? Curious
I'm running two 10watt Renogy little panels full sun hot 85-100 degree day the two little panels were putting out a solid 1amp with occasional spikes above that. In my case our power needs are pretty low just small LED lighting and very small electronics charging Gopro, Ipad cell phone etc. Which case my solar generator is a 50caliber ammo box bolted to my trailer which houses a 18ah deep cycle battery, off grid light post solar controller with a power output for a light 20amps max which case I set the output to 24/7 always on and powered a small 6 fuse - fuse block which is what I power our lighting and charging hub from. This way the solar controller manages the battery health both incoming juice and outgoing juice everything fit and is mounted in the 50caliber ammo box. So far so good. Worst case use being power pigs we seem to burn a max of about 8-9ah's over night and the two little 10watt panels had us back up to near fully charged by 2pm going to float status which case I plugged in a cellphone and I pad and had those charged up before the sun went down. So were very very light on the power capacity but we also have a very light power need. Primarily lighting and small device charging. So far its been great.
FJR Colorado
I have a very similar set-up built into my truck topper. My charge controller is from Renogy and my battery is a Yellowtop Optima. If the battery you use is good, you should have no trouble running the ARB fridge 24/7/365 as I do.
See my Tundra build thread for details.
Nice clean work.
Javelinadave
This turns out to be a great week to test things out. Record heat (114F/45C) yesterday and hotter (115F/46C) today. Here is the data thus far.
Battery started the test at 13.0v at 10:00a yesterday and the fridge set and pre-cooled to 32F (0C).
07:00a this morning the battery was at 12.4v and the evening low was 82F (28C)
08:30a I lower the t-stat to 30F (-1C).
Stay tuned for further updates!
Clemtiger84
