What did you do to your Mitsubishi today?
bikerjosh
Installed skid plates and replaced broken grill
Bolted up the new skids and replaced the cracked broken plastic grill with a piece of expanded metal.
Also noticed the majority of my driver side inboard CV boot is gone. Whoops, looks like it is tie for a new axle, probably been like that for a while.
lordtrunks
camp loser
pulled leaking injection pump installed new front seal, it was too late in the day to grab the gaskets i need for the side cover plates from perkins so in the morning i'll stop over there for them, fingers crossed they will have them in stock.
Porvalsh
Pulled the air blower to see if I could figure out what the little tick tick tick sound from it was. Cleaned out air box, couldn't seem to find any debris. Hooked up blower outside of its mounting location and it sounds the same. Going to see about getting a new blower. Its annoying me.
BOPOH
pulled my friend out of a puddle and after that i got something short circuited, every time i hit brakes or switch an electrical component i get flicker
brad2274
I have the same issue, has like whirrr noise almost a buzzing, sounds like a window mount Ac unit its so annoying
Sabre
Overlanding Nurse
Yesterday I finished painting the skid plate I built for protecting the transmission. Steel frame members with aluminum plate skid.
Smudge12
