Trixter404's 2011 Night Armor Xterra
Trixter404
Intro Photo:
Make: Nissan
Year: 2011
Model: Xterra
Trim: S
Color: Night Armor
MODIFICATIONS
Suspension, Lift and Tires:
Nisstec 1" Lift Top Plate Spacer (9/18/15)
Nisstec MK84 Extended Travel Lift Kit (9/18/15)
• Nisstec MK84 2.0 Extended Travel Coilovers w/ 650 lb. Eibach Springs
• SPC Extended Travel UCA's (coil buckets modified)
• Nisstec Adjustable Rear Shackles
• Bilstein 5125 Series Extended Travel Rear Shocks (2"-2.5" lift)
PRG Deaver 2" Rear AAL (6/29/13)
Helper Springs (3/16)
PRG Cam Bolts (8/13)
Goodyear Wrangler Duratracs 285/75/16 x5 (8/3/13)
SpiderTrax 1.5" Hub Centric Wheel Spacers x4 (10/16)
Front Sway Bar removed (10/16)
Rear Sway Bar removed (8/13)
Engine/Drivetrain/Performance:
Volant 12740 Cold Air Intake (2/18)
Airflow Snorkel (4/16) (Offroad Gorilla group buy)
eBay Snorkel Head (11/17)
AEM Dryflow Air Filter (8/28/13)
Rear Diff. Breather Extension (4/16)
No-Spill Systems Oil Drain Plug & Tubes (12/16)
My Lead Foot
Armor:
Hefty Fabworks Front Winch Bumper (4/16)
Max-Gear Armor (Maxterra) Rear Bumper w/ Tire Carrier & Jerry Can Holder (11/16)
Hefty Fabworks Skids (7/15 )
• Radiator
• Engine
• Transmission
• Transfer Case
• Fuel Tank
White Knuckle Sliders (1/5/14)
Ballistic Fabrication Rear Differential Cover (4/16) (purchased from TNX member)
Exterior:
Gobi Passenger Side Ladder (5/15) (group buy)
Gobi Tailgate Gas Struts (5/15) (group buy)
Offroad Gorilla Hood Gas Strut Kit[ (7/15) (group buy)
Nissan Side Window Deflectors (5/16)
Cheap but Sturdy QuickFist OEM Roof Rack Attachment
Tuff Stuff Overland RTT w/ Annex (seasonal)
Yakima RidgeBack 4-bike Hitch Rack (seasonal)
Yakima Big PowderHound (seasonal)
OEM Crossbars added (purchased from TNX member)
iJDMTOY Black Front Bumper License Plate Re-locator Bracket
"Stealthed" '05-'08 Grille (5/16)
"Stealthed" Rear Bumper (5/15)
Shadow Chrome Black Grill Emblem (7/16)
Splash Guards removed (6/13)
Melt Mod (8/3/13)
Bosch ICON Wiper Blades
Decals
Electrical & Lighting:
HID Projector Retrofit (4/16)
• Kensun HID 35w Headlight Conversion Kit
• Nilight 2.5" Mini HID Bi-Xenon Projector Lens/Shroud x2
• Kensun HID H1 Bulbs - 5000k
DNA Motoring LED Fog Lights - 3000k (9/17)
Easy Fog Light Bypass (4/16)
OEM Fog Light Switch added (6/13)
Philips Vision 921 LED Backup Lights - 6000k (10/15)
Philips Vision 3157 LED Tail Lights - Red (11/15)
Philips Vision 3157 LED Rear Turn Signals - Red (11/15)
Diode Dynamics HP48 3157 LED Front Turn Signals - Amber (12/15)
Aaron 50W 6ohm Load Resistors x4 (2 ea. connected in parallel at rear - 11/15)
Diode Dynamics HP3 LED Front Side Markers - Amber (3/16)
Diode Dynamics SMF6 Dome/Map/Trunk LED Lights (5/17)
OEM 7-pin Tow Harness added (6/13)
Uniden PRO520XL CB Radio (11/24/13)
Astatic 302-636L Noise Cancelling CB Microphone (8/14)
FireStik FireFly 3' Tunable Tip CB Antenna
FireStik SS-3H HD Antenna Spring (11/29/13)
FireStik SS-184A Antenna Mount (5/17)
Switch-Pro SP-8100 (7/17)
TEMCo Industrial 42" LED Flood/Spot Combo Light Bar (3/15)
Offroad Gorilla Dual Light Bar Roof Mounts (3/15)
MicTuning 22" Amber/White Dual Function LED Light Bar (2/18)
LED Kingdom 4" LED Cubes x2 (11/17)
IF Rear Xterra Light Bar Mount (11/17)
Interior & Electronics:
Pioneer FH-X700BT Stereo (3/13)
Garmin Nuvi 50LM GPS
Samsung Galaxy Tab S2 8" Tablet w/ Backcountry Navigator Topo GPS app
Excelvan Car Floor Seat Bolt Mount Tablet Holder Stand
Coverking Neoprene Front Seat Covers - Black (12/17)
WeatherTech DigitalFit FloorLiner (front only) (10/28/13)
Nissan All Weather Floor Mat (rear seats only) (5/17)
Auto-dimming Rear View Mirror w/ Compass (8/17)(thank you Snowtrout)
BESTEK Dual 110V AC Outlet and Dual USB 3.1A 300w Power Inverter (3/14)
Utili-track Cleats Substitute
Rear Cargo Cover
Rear Cargo Net
Recovery & Trail Gear:
Engo E10000S Winch (4/16)
Factor 55 ProLink (4/16)
CSI D-Ring Recovery Hitch
ARB Recovery Gear Bag
• ARB 4" x 30' Recovery Strap
• Smittybilt 3" x 30' Recovery Strap
• Driver 3" x 10' Tree Saver Strap
• Smittybilt D-Ring Shackles
• Smittybilt Snatch Block
• ARB E-Z Deflator
TRED Pro Total Recovery & Extraction Boards x2 (via KickStarter)
48" Hi-Lift Jack
Hi-Lift Jack 2" Tube Mounts
D-grip Handle Shovel
Coghlan's Folding Shovel
VIAIR 400P-Automatic Air Compressor
Amflo 25' 120psi Hose & Campbell Hausfeld MP6000 Tire Inflator w/Gauge (backup)
STIHL MS 211 C-BE Chain Saw
Fiskars X15 Chopping Axe
STIHL PS 30 Folding Saw
Trasharoo (ExPo group buy)
Flashlights
LED Headlamp
OEM First Aid Bag added
Fire Extinguishers
Tools
Jumper Cables
8-Gallon Rubbermaid ActionPackers x3
5-Gallon Fuel Jerry Cans x2
5-Gallon Water Container
Ordered/Purchased/Not Yet Installed:
Blue Sea Systems 12-Circuit Fuse Block
Rockford Fosgate Battery Terminal
LED Kingdom 4" LED Cubes x4
What's Next?
Leaf Spring Replacement!
Interior Cargo Rack
Fridge/Freezer
OBA
Air Locker(s)
Maintenance
Fluids:
• Front/Rear Differentials - Mobil 1 75w90 Synthetic Gear Lube LS (@75k)
• Transfer Case - Nissan Matic D (@75k)
• Engine - Mobil 1 Extended Performance Full Synthetic 5w30 (@112.5k)
Service:
• Transmission (@107k)
• Brake Fluid (@107k)
• Radiator (@107k)
• Spark Plugs (@107k)
Trixter404
My recent upgrades include a set of Hefty Fabworks skid plates (way overdue) and Offroad Gorilla hood gas struts to replace the OEM rod. I'm looking forward to receiving and installing the new Nisstec lift that I ordered last week to replace the PRG lift spacers that I currently have.
jhberria
Same here. I might actually go up Friday night and find a place to camp, make a full weekend out of it. I'm thinking about starting a thread on here to gauge interest from the ExPo folks.
Also, this will be my first run with the NWXC crew. Should I expect to be hazed? Will there be paddling involved? So many questions that need to be answered.......
Trixter404
Great setup, have you thought of a storage setup?
Thank you! I haven't decided what direction I want to go as far as storage. Right now I'm just using a combination of 8-gal ActionPackers and 20-gal Husky totes. Easy to transfer from my garage and back again.
Trixter404
Details on the roof rack?
Truck looks great!
Thanks! The roof rack was a made by my cousin's son (2nd cousin I guess??) who was only 17 at the time and trying to get into fabrication. It's inspired by the DepHep roof rack (hepsdesigns.com) made exclusively for Xterras. The idea was to have some extra storage space that was low profile, unlike the Curt rooftop gear basket that I previously had mounted on top of the OEM crossbars. This rack drops in between the roof bars allowing stored items to sit 4-5 inches lower and it's much more rugged. In the end, this rack is really just holding me over until I get a full Gobi rack and RTT.
Here are a couple pics:
jhberria
Nice! Are you going to be able to get all that installed before the fortune creek run this weekend? What spring rate did you get on the Coilovers?
vertical.dan
