COMEUP
Supporting Sponsor - COMEUP Winches
Time to spotlight one of our popular winches.
SEAL Gen2 9.5rsi
This is one of our most popular winches for the offroad community because of its size and pulling power. It's tough, fast, and strong. Features a wireless remote and comes with 100' Synthetic winch rope.
•12V DC severe duty winch rated at 9,500 lb pulling meets or exceeds your expectations.
•Heavy duty series wound motor equipped with thermal switch alters when motor is over-heating.
•4 equally positioned pin holes with a stainless steel ergonomic T-handle make it possible to clock in 90 degree Increments.
•Water-proof remote control with thermometric LED indicator w/5 m cord
•Tough aluminum die cast housings withstand strength of 2.0 x rated load of winch
•The U.S. Germany, U.K. France, etc patented mechanical cone brake outside the drum expedites heat dispersion. The greater the load on the rope, the greater amount of braking is generated by the mechanism.
•Meets SAE J706, CE Machinery Directive 2006/42/EC and CE Electromagnetic Compatibility Directive 2004/108/EC.
Specifications:
Rated Line Pull 9,500 lbs (4,309 kg) single line
Motor 5.0 hp / 3,730 w 12V Series Wound
Gear Ratio 3-Stage Planetary 159:1
Clutch (freespooling) Rotating Ring Gear
Brake (outside the drum) Automatic, full load CBS (Cone Brake Structure)
Winch Construction Aluminum Die Cast Housing with Steel Drum
Drum Size 2.5" x 9" (63.5 x 228 mm)
Control Both built-in digital two way signal wireless remote control and waterproof remote with thermometric indicator LED w/17' (5 m) cord
Rope Type Synthetic Rope SK-75
Rope Size 3/8" x 100' (10 mm x 30.5 m)
Mounting Bolt Pattern 10" x 4.5" (254 x 114 mm)
Winch Weight 61.7 lb (28 kg)
Gross Weigh 89.1 lb (40.5 kg)
Warranty Limited lifetime warranty for mechanical components, three (3) year warranty for electrical components
Box Dimensions 26.9" x 8.2" x 16.9" (682 x 209 x 430 mm )
Get it here:
http://shop.comeupusa.com/p/seal-gen2-9-5rs-12v-winch?pp=12
SEAL Gen2 9.5rsi
Specifications:
Get it here:
