Vanimal: 4x4 Sprinter build
mk216v
Der Chef der Fahrzeuge
Very jealous of the off the shelf RB Components available. Choose, order, install, done.
Kgorman
Hi
I have a Outsidevan Sprinter and I am deciding on new tires. MY Kumho's are great on the road but get damaged easily on dirt roads. I noticed that you chose Toyo Open Country did you look at GoodYearSilent Armor? I am trying to decide between the two. BTW Great job on the interior!
I looked at the Goodyear Duratrac and Nitto Trail Grapplers. But because I have run the Toyos on the F350 I knew they ruled. So I went with them. So far, no regrets.
Nice van! Thats what I am modeling my setup after!
srqsup
Thanks for the input. My van is a bit different inside. As I have two couches that pull into a queen/king bed. the back is a dedicated sports equipment garage completely separated from the living quarters with its own 110v outlet and lights.
Kgorman
Quick update.
Tomorrow the remainder of the bench components show up. This is the seat back that folds down in order to make the lower bed one complete piece. It should be bolt on. It should look like this:
I picked up some aluminum C channel in order to mount the hammock style upper bed. I went *way* overboard in terms of designing it because I am worried about flex in two directions. Down as well as towards the inside of the van. The C channel is 3" x 1/4" x 105". It's huge and beefy and doesn't flex a bit. I ordered footmans loops that bolt to it and support the straps to the hammock. I will post pics once I get it all setup.
We are about 16 days from leaving for our trip so it's crunch time!
350outrage
Great day! The kids caught Lots of fish, we all got dirty on the UTV, and lots of great memories were made. This is why we bought this thing and we are getting tons of use out if it already.
I am glad I got 4x4, there was one spot today where I needed 4 low and it turned out great. It got the rig and trailer through the tricky spots.
Yes, maneuvering a trailer over dicey surfaces is where the 4wd really comes into its own. Heavier the trailer, the more you need the 4wd.
Kgorman
A quick tip. Cleaning out the van is a snap by just opening the back doors and using your yard blower to blow out the inside. Cleans up even inside the l-track.
Cole
Haha.......and I thought I was cheating using my Powertank and an air nozzle :sombrero:
Accrete
As others have noted...great foundation. Best wishes on the build and adventures.
Mounted Toyo Open Country LT265/75r16 including the spare...
We've been running the OCs for some time on our AWD van at the Oregon Coast...they've been nice in the wet stuff.
Thom
Kgorman
I have been feverishly working on the van in the evenings trying to get ready for our Thanksgiving trip. We leave Friday. But it's coming together.
I took a major left turn when we rigged up the Van Hammock and the kids and wife wanted a hard bed. So I had to get creative. I already had designed a aluminum beam structure that was mounted on each side of the van that supports the hammock including nice loops for securing the webbing. But once the kiddos boycotted then I needed a new solution. I sat on the new couch in the back and had a beer pondering the situation and realized someone, somewhere, had mentioned Motorcycle ramps from Harbor Freight work nicely. I googled, and just about spit out my beer. These tri-fold ramps fit within 1/2". As much as I hate cheap imported crap I jumped in the truck and headed over to HF. I got two tri-fold ramps for $99 each. They are beyond perfect. They fit near exactly, they fold up, they are strong without any flex. We just use our air-mattress as a pad and inflate it using the Goal Zero 400. I did a test run with the kids in the sleeping bags and they are stoked! Whew. I am going to keep the hammock setup for when we have a 'guys trip' and we perhaps want some more flexibility, as it's a very nicely made unit, and I find it comfy myself.
Another problem came up. When I went to install the center section of the lower bed that RB sent me, it didn't fit. This is the center section that flips into place to join the two benches. I called RB and they told me to use a new set of brackets they included. Sure enough those brackets looked like they would ensure a good fit. But I couldn't use them. I had already laid out the nice brackets for the benches and got everything complete, I wasn't about to start ripping stuff down and drilling more holes. Ultimately the answer was to drill a new hole that ensured proper spacing in the *existing* brackets. The drill press came in handy again! Everything fits like a glove now. I had to modify only one side, and I left the other as-is. Works perfect now.
I added new LED light bulbs, ordered an extension for the Goal Zero car charger (I will hard wire eventually), got the RB components gear bags secured, added more l-track, and started to pretend pack so we can adjust spacing on things as needed.
We are almost to what I envisioned version 1.0 of Vanimal being, just a few more things. We leave in 2 days so I have to get the rest of these little things done. I will post more pics as I get them done.
Kgorman
A couple more notes...
The aluminum channel holding up the ramps is a 'C' channel from our local metals place. It's 1-1/2" x 3" channel. It's shape is like 1/2 of an I beam. I will try to get a close up pic. The purpose of this massive beam was to have strength in 2 directions. I secured it using 6mm riv-nuts x 6 for each beam into the vertical pillars in the van. It's beyond solid. I did have a problem with me doing a bad job on one riv-nut. ;-(. The channel works nicely for side loads as well as putting something on top like the platform. When I was designing it, I was thinking about making sure I could put something on top of it as well as suspended sideways from it. I am a nerd for flexible systems and I didn't know how this would work out exactly, so I over-designed it.
We also put up the insulation. I had a couple friends over and we added the Thinsulate everywhere. It took 4 of us about 3 hours to get the entire van done sans ceiling. You can see in this picture the riv-nuts for the beam as well.
