jasonsuperb
So I just got back from a 5 hour drive down to Virginia and back to pick up a 2003 Mitsubishi Montero Limited with 89k. The truck is beautiful inside and out, really nice condition. Has a few issues to iron out but mostly maintenance stuff. This is what I have so far on the list.
ASAP:
Replace Belt and idler pulley (DONE)
Replace air filter (DONE)
Replace broken rattling subwoofer (DONE)
Fix Coolant leak at the back of the truck (just found that when I got home) was surprised there were coolant lines all the way back there (DONE - HOPEFULLY )
In the near future:
replace valve cover gaskets
Timing belt
replace all fluids
Shocks
My goal with this truck is to keep it as stock as possible while also being a fun off road tripping mobile.
I already have an over the top landcruiser fj60 for tough trails so I want to keep this one very simple and stock looking.
The car drove great on the way back from Virginia but I had a few impressions that maybe some other montero owners will have some insight into.
The suspension is not as plush as I was expecting, its not bad by any means just not as smooth and plush as people say. I am assuming it is the stock shocks that need to be replaced. So that is on the list. However that leaves the question to just get stock replacements or something better. From what I could find Bilstein makes 4600 stock replacements. OME makes a 1.5 lift kit and RADFLO makes a coil over adjustable front from 1" to 2.5" lift but with just replacement shocks in the back. Seems like the RADFLO would be the best option but then the rear might be a bit lower than the front. I would be happy with as little lift as possible. My landcruiser is wayyy to high.
The rpms were a little higher than I was expecting on the highway making the engine a little bit noisier than ideal. at 70 they were at around 2800rpm. Would be awesome if it was a 2200 at 70 but I guess that isn't going to happen. A larger tire would help a bit but not much, and then it might drop down in the 4th more often. Any one fit 33s with stock suspension? Or do you need a small lift for them. Thinking 285/75/16 or 255/85/16 would prefer the 255, but they seem to be only available in an MT tread and I really want an AT tread for this truck.
Well more to come, really excited about this truck. Coming from driving only 30 year old land cruisers for years it is a huge change.
ASAP:
In the near future:
Timing belt
replace all fluids
Shocks
