95 E350 build
Paul E Dude
I been stalking a while. thought I would post some of my progress..
94 E350 7.3 IDI diesel I scored for $600. and drove it home.. Only took $1000 to get it back to stock from the P.O. "repairs"
The day I got it.
In Alaska
Paul E Dude
and it start to go in
First test fit. First thought to move the axle out. But decided 3" was way too far.Was shooting for 1 1/2" Later I cut them down, Now I think I have 1 1/4" longer wheelbase. Did I mention those leaves are long. But they will be easy to find if I get stranded somewhere.
I still plan to gusset the hanger off the front of the frame at the bumper mount.
Paul E Dude
Its big! But should settle.
Had to grind a knotch in the van brake line. They were acualy longer then the truck lines. I was able to turn them 90* and re bend the hard end to point up. Then I cut the hard mount off the frame, and re welded it lower. Now if I have a problem on the road somewhere I should be able to get those parts too.
Paul E Dude
Made a rear pack out of the Van main leaf and the F350 leaves and block. Once the front settles in place I will decide on a rear pack, if I need it.
Just a bit higher in the front. I need to drive it. I hope it settles. I don't have the winch in the mount yet. debating on what bumper I want to build too.
E350 pitman arm left. F350 on right. I put the F350 on without any problem.
Paul E Dude
I drove it today. No track bar, welded draglink sleeved to extend it. Its at a harsh angle. Yea I got death wobble! But I did get the springs to settle. Now to pull off the knuckle and have it machined for crossover steering. After I get that in I will know where to put the trac bar.
I extended the factory sway bar links
Used the factory shock mounts I cut off the front spring hanger, and bolted them in temporary to the rear. They have a big fender washer filling the hole so I added 2 tac welds till I figure out my ride hight in the front. Friend gave me some free Ranchos, so I put them on.
Paul E Dude
Still a little big. I will prob take a leaf out.
How I make shade. took the knuckle off to ship off to the Machine shop to get Hi Steer arm
goneagain
I think 95 was the switch year for IDI/PSD.
OP, your death wobble...any idea whats up with that? What are your caster/toe angles? seems strange youd have any wobble.
philos
Death wobble in this context seems to do with steering angles more than anything else.
Keep the drag link, etc parallel and you'll be good, hence the high steer, no?
goneagain
You would be correct if he had a linked suspension. with linked geometry, the axle is centered by a panhard bar that runs parallel to the drag link. if it is not parallel, the panhard operates on a different radius, and the draglink absorbs the axles side to side movement, causing bumpsteer.
On a leaf sprung rig there's really nothing to parallel the draglink to. his axle is centered by his leaf springs. His suspension is traveling up and down, not diagonally like a link suspension. being that he used a relatively low spring, there shouldn't be any side to side movement requiring a panhard bar. Although superdutys used them in the early days, I believe it was a preventative measure more than anything else. IE. they drove fine without them.
most often than not, deathwobble on a leaf sprung rig is due to too much or too little toe angle. even if the caster is way off, it can be made to drive straight down the road by compensating in the toe angle. If the toe is set to spec, but the caster is way off, the toe is off as well.
The OP used the OEM ford leaf springs. My hunch is the front and rear spring hanger elevations came out a little different than when under the donor truck.that would place the OE axle caster off, throwing the oem toe angle specs out the window.
Goldenbora
