M1078 LMTV expedition vehicle build
hey there! Just received a 150 gallon custom sized tank from Propower manufacturing in ontario, Canada. they were super easy to work with and a quick turn around time. now I have a 1100+ mile range!
That's in addition to your stock tank? Where are you mounting it?
Both sound accurate.
Every single person I've met and talked to over the years that have owned and traveled using these have always reported between 6 and 8 MPG
Never more, never less.
They dont have the best diesel engine, but it is a diesel that falls into my "dumb diesel" category.
As in, a diesel that is too "dumb" to know or even care about how much its hauling or towing, and gets the same MPG regardless.
Most diesels in this category are also fairly dependent upon operating RPM when it comes to fuel mileage as well.
Simply, the higher the RPM, the lower the MPG. So the ones reporting higher MPG are often the ones keeping the engine at a lower RPM on the highway.
Driving from tucson to portland in our 1088 from the DRMO lot, i held speed at roughly 50-53mph and got 7.6mpg. what engine do you have?
The 3116. I also have the added weight of a bed and the wind sail of a cargo cover so that might save you some but will be deducted once you get your box on.
We've been makings steady progress, but you can really start to see it come together recently. All the painting is done and we are starting to reassemble all the refurbished parts.
Michael
Looks great! I really like the care and detail your putting into your build. I too will being (most likely) going down the LMTV route. Looking forward to see how the living accommodations turn out.
Thanks for sharing.
Jlbeats
