Ski Bum Truck V2.0, F450 Rough Road RV
DzlToy
Do you have a GoPro or similar?
Find one to borrow if you don't and mount it on your axle (securely) and go hit some pot holes. That will tell you exactly what is hitting, when, how much the bump stops are compressing, etc..
java
Oh good idea! I do have one, I'm sure I can figure a mount out
Sent from my SM-G900T using Tapatalk
java
Found a few hours yesterday between soccer practice, dinner and homework with the kid....
Propane tank mud flap is done, man are those things hard to cut!
Bolted to the body on the outside
and a piece of cable on the inside. Hopefully this keeps it off the tire. Handy slot/hole was already in the spring hanger, I think it will stay put.
Finished up the last big wall panel, still lots of trim work, and skinning the door. But this piece keeps the insulation in place and give it a much more complete feel.
Caulked in the back side, this is kinda a "wet room" skis, ez up sleds etc. That should keep the water from running under the floor into the living space. There is a fair bit of storage back there, but I wish I had made it 1" deeper....
Got the inverter mounted, and the hot side cable done. Man everything takes FOREVER! Climb under bed, forget some little piece/tool, climb out, walk to garage, climb back under bed. Repeat ad nauseum.
gtbensley
Not yet. Its just barely visible that it has leaked on the dip stick now, its been ~1000 miles. I am getting some little black dots on the back doors though.
I will likely do the injector harness and leave the oil pan alone, its just a huge PITA to get out. Its not leaking fast enough to go to the top of the priority list. I need to get the up pipes done though, it gets stinky in the cab randomly it seems...
Most diesels seem to leak some anyways, not a big deal. Get those up pipes fixed though, that can cause you to have higher EGT's which can cause problems.
java
Yeah id like to fix it anyway, its enough to get droplets on the back doors which is annoying. Its on the list...
The up pipes are weird... Trip before last it STUNK going down the freeway at 65 had to open windows it stunk so bad. Last trip we did 350 miles, I got a slight smell on a regen cycle, wife didn't even say anything about it and shes usually pretty sensitive to it. I am still making ~35 psi boost going up the passes, which is right about where it should be from my reading online (stock is supposed to top out just under 40) so it cant be leaking that much. I have been meaning to grab my OBDII dongle to see if I can get EGT data from it. I think I can.
java
Frame to axle measurement would be more accurate.
OK dug through the body builder book. It has frame to ground measurements at front axle center line. Which is nearly impossible to measure on a assembled truck but should get us close. One thing to keep in mind its for a CC truck, mine was a pickup (should not be a difference forward of the cab). I should be between 25" (unloaded) and 23.6" (loaded). Im not on a super flat spot but ill take some measurements and see.
java
Broke out the tape, the front of the truck is probably 8-12" above the rear in the parking spot. I'm roughly 23 ish inches in the front. So fully loaded.
java
I would think egt temps would show up on a scanner on something that new.
I think so too, just gotta find time to try it! I did get a conduit run to my tool box and my inverter/charger installed. So I now have a 120V plug I can run from my tool box to any outlet and charge! I just need to get the 120V side of the inverter done, I didn't have a big enough knock out :(
Drove it again on the weekend. It drives nice. Really nice. Still smells like mice though :(
guidolyons
Addicted to Gear Oil
OBD bluetooth dongle and TorquePro app (Car Gauge Pro interface is not as slick and Torque Pro, but Car gauge Pro can do injector buzz test and cylinder contribution test) on your phone will get you a lot of cool info. EGT, coolant temp, RPM, volts, read/clear codes, you can tailor it to see PID/live data for most anything anything the ECU sees. Displayed as a gauge or graph.
java
OBD bluetooth dongle and TorquePro app (Car Gauge Pro interface is not as slick and Torque Pro, but Car gauge Pro can do injector buzz test and cylinder contribution test) on your phone will get you a lot of cool info. EGT, coolant temp, RPM, volts, read/clear codes, you can tailor it to see live data for anything the ECU sees. Displayed as a gauge or graph.
I've got Torque lite and a Bluetooth dongle, I'll try it. Just gotta find time.... Weddings and work are cutting into my truck work time.
Ordered solar goodies today :)
keons500
This. Your project is awesome! One of the projects that inspires me regularly. Keep it up!
I did end up getting a different fridge FYI. Your thread is how I learned about Isotherm, but I found a pretty decent deal on a Vitrifrigo C130 (same Danfoss Compressor). It's not the drawer, but that doesn't much matter.
java
Glad it's an inspiration! Really I do.
So many little things to do. Solar is ready for install, water needs to get done too.
java
100W folding panel, looks like they took one of the "flexible" panels and cut it in half. Its very small when folded. It will be paired with a Victron MPPT controller.
Charger is wired. Ran a piece of flextite conduit between the tool box on the drivers side and the battery area. This is so I can run my incoming power cable from there. Also ran a pair of 8 gauge wires for the solar hook up. The solar controller will likely be mounted next to the batteries though. The other two glands re for my 2/0 DC power wires.
And in the box I have about 20' of 20 amp cord, and the two solar wires. Tools and fluids live there too.
And wires up to the inverter charger.
Also started on my 120V breaker box.
Then it was time for more holes..... Water heater intake/exhaust.
I even managed to get the hole from the inside and outside to line up :D
Its a concentric vent, intake around the outside, exhaust down the middle. All stainless which is nice.
And all done.
And since It was almost 90 yesterday we thought we should give sticker peeling a go! Man it came off so much better than when it was cold out! No more sponsor names, just the number either side now. There was even a second layer of blue on the front!
