Colorado_Outback
Thats the easiest way to make custom compound bends, at least until I get a tube bender.
Well I thought I was clever enough to get this welded up without building a jig. I witness marked all the joints and broke it apart so i wouldn't be putting a ton of heat into the long pipes. I welded up the bends and all the witness marks lined up, I thought I was home free and this is where I made the critical error. I forgot how much shrinkage can occur, I should have rechecked the fit before welding the long pieces to the bends. Had I done that I would have found the cross over 3/8" short and the doughnut gaskets impossible to seat. Unfortunately I had to split the cross over and extend it to get it fitting correctly. It doesn't look as elegant as my original but I only spent a couple hundred fixing my whole exhaust and learned some things so I'm calling it success.
Got the 02 bungs welded to the down pipes.
20170309_143335 by colorado_baja, on Flickr
I bought this truck from a high school kid and in his infinite wisdom he did a muffler delete on it (leaving that enormous cat up front) and did a crappy job of welding the straight pipe in. I got rid of all that and put an Allied street max muffler on it. Guy at the exhaust shop said it wont be too loud. Its straight through perforated tube with a glass packed case. I'm skeptical but it was cheep, only review I could find online is V6 Mustang guys complaing about them being too quiet so we'll see.
20170308_140531 by colorado_baja, on Flickr
