Some Fuso shots from the 2017 Abenteuer Allrad show, Bad Kissingen, Germany
dhackney
dhackney
If you are in Germany. ;)
Note that the camper boxes will bolt onto a Fuso (or other brand) chassis wherever on the planet that chassis happens to be located.
Depending on the size of the camper box, you can ship the camper box in a container anywhere on the planet to match up with a chassis.
If it's too big to fit in a container you can ship it flat-rack.
Or, you can ship your local-market chassis to Germany, bolt on the camper box and then drive it RTW home.
MarcusBrody
What's the top of cab fascia for? Strictly aero? I can't tell for sure, but the storage doesn't appear to be it's full depth.
dhackney
Unknown.
The brochure is here: http://www.woelcke.de/files/userfiles/files/Prospekte/Autark-explorer.pdf
Google Translate of the Brochure is:
QUALITY OF WOELCKE
highly-compact, nimble-robust fully insulated Autonomy
Autar k
Fuso Canter 4x4
Total length ~ 6370 mm, total width ~ 2012 mm, total height ~ 3390 mm,
175 hp / 129 KW - 3.0 ltr. Displacement - z.GG 6500 kg - load over 1000 kg
self-sufficient
Autark Explorer E2
Housing for 2 persons with rear seat group and great freedom of movement
Double bed - 2000 x 1400 mm
Windows: 6 x 900 x 500, 1 x 350 x 500
Roof hatches: 2 x 400 x 400
Can be locked to driver's cab
Storage space under bed - 2000 x 1300 x 600 mm, storage space flaps 2 x 1100 x 500 mm
Expansion as described in equipment
Autark Explorer E3
Housing construction with large bathroom and XXL kitchen
Windows: 2 x 900 x 500, 1 x 1200 x 500, 1 x 350 x 500
Storage space under bed - 2000 x 900 x 900, storage space flaps: 2 x 850 x 850 mm
Expansion as described in equipment.
Autark Explorer EL 4460
Empty luggage compartment for individual removal with entrance doors and foldable entrance
Internal length: 4460 mm, internal width: 2000 mm, optional windows, storage space flaps, roof hatches ...
Self-sufficient ground plans
Wheelbase 3415mm - total length ~ 6370mm, total width ~ 2012mm, total height ~ 3390mm
Incl. Entrance doors, entrance and roof elevation and intermediate frames
Errors and misprints excepted
1107/5000
Autark Explorer E4
Housing for 2 persons with large bathroom, separate kitchen and XXL seat dinette
Windows: 4 x 900 x 500, 1 x 350 x 500
Storage space under bed - 2000 x 1300 x 900 mm
Storage space flaps: 2 x 1000 x 850 mm
Autark Explorer E5
Housing for 2 persons with large room bath, XXL kitchen and longitudinal beds
2 x longitudinal bed - 1900 x 800 mm - central intermediate cushion.
Windows: 3 x 900 x 500, 1 x 1200 x 500, 1 x 350 x 500
Basic self-sufficient
Autark Explorer EL 4960
Internal length: 4960 mm, internal width: 2000 mm, optional window, storage space ...
Wheelbase 3865mm - total length ~ 6870mm, total width ~ 2012mm, total height ~ 3390mm
The Fuso Canter is one of the best-selling light trucks worldwide in the class up to 7.5 tons
Permissible total weight, which in Germany with the driving license "the old 3-er"
Can be driven. A driving license for driving a heavy-
Trucks are therefore not necessary.
The Fuso 4x4 is very light and offers over a ton of residual load with lush equipment
After fulfillment of the vacant empty weight.
The ground clearance with ~ 32cm (with serial tires) is big enough for trips off the road.
With an outer width of ~ 2.12m, we are extremely agile in the light truck class, so narrow
Mountain roads and narrow inner cities are not obstacles.
The total length of ~ 6,37m and ~ 6,87m are with the different Autark Explorervarianten with
Their generous ground plans and equipment very compact also by the short cab
The Fuso Canter 4x4.
Also the largest possible total height of ~ 3,39m (with single tires 255/100 R16- railings)
Includes a fully insulated and heated "water tank" and heated function floor.
We would like to convince you of this compact long distance travel motorhome.
Woelcke
Individual travel agency
special vehicle
dhackney
Woelcke - Autark Explorer
Price list from 04-2017
Fuso Canter 4x4
Wheel drive
Engine power: 129KW (175HP, 3500 rpm, 430Nm), two wheelbases 3415mm and 3865mm
Motor design. Blue-Tec - EURO 6, main tank 100 ltr.
Transmission: 5-speed manual, Total permissible weight: 6500kg
Angle of slope front: 35 °, angle of inclination behind: 25 °, ramp angle: 25 °
Turning circle: 14.9m with wheelbase 3415mm, turning circle: 16.5m with wheelbase 3865mm
Total load weight 10,000kg
Axles and suspension:
Differential lock with limited slip
Speed ​​gearbox (1.090 / 1.987) can be activated
Axis translation: i = 4.875
Wheel and tires:
Traction tire, complete
Spare wheel holder-double secured
Spare wheel / spare wheel rim
Optional single ripening
Frame and frame components:
construction devices
Main tank 100 ltr.
Rear underride guard
brake system:
ABS with electronic brake force distribution
Cab Exterior:
Comfort single cabin
Central locking with 2 radio remote controls
Cab inside:
Driving comfort swing seat, horizontal suspension, armrest driver's seat
Passenger double seat seat backrest fold-down Optional single-passenger comfort swing seat
Airbag driver and passenger
Instrument lighting infinitely variable
Glove compartment
Storage box on vehicle rear and storage via windshield, 1 compartment
Immobilizer with transponder
Electric
Daytime running lights automatically
Fog lights halogen
Equipment adapted to floor plans in the brochure:
Autark "Explorer" on Fuso Canter 4x4
3-D - roof and side spoiler / wind deflector "Woelcke-Autark-Explorer"
Clearly more space and space in the driver's cab
Inside storage compartments right and left
Insulation lining with noise reduction measures
GFK -wohnaufbau (GRP = glass fiber reinforced plastic)
- Self-supporting - Roof fully walkable - Fully insulated - Cold bridges free
- Corrosion resistant - Fully bonded - Suitable for winter use
Walls and roof made of 50mm GRP composite panels
Outer layer: 2mm GRP high-gloss white gelcoat (similar to RAL9016)
PU-RG-50 (polyurethane) - insulating foam core - closed pore without inserts and cold bridges
Cover layer inside: 2mm GRP high-gloss white- Gelcoat (similar to RAL9016)
Other cover layers, wall and roof thickness optional
Floor made of 50mm GRP composite panel
Outer layer: 2mm GRP -white-
12 / 13mm multiplex (Finnish birch water resistant glued)
Cover layer inside: 2mm GRP high-gloss white (similar to RAL9016)
Outer and inner edges
GRP inner angle 30x30x3mm made of fiber laminate all-round glued
GRP outer corner 90x90x3mm made of fiberglass laminate, roof walls, fully glued
GRP outer corner 100x60x3mm made of fiber laminate, floor panels, fully glued
GRP outer corner flaps (additional reinforcements outside) to the transition walls-floor.
bonding:
Fully bonded with PUR special adhesive
Rear wall-roof front wall, seamless, one-piece with curves / bevels front and rear
Front bevel: 45 ° round bevel
Rear rounding: roof top rounding R = 200mm
Inclination angle in the stern: Ground round bevel 45 °
External Length: ~ 4570mm - Inner Dimension ~ 4460mm (Autark Explorer: EL4460, E2, E3)
External Length: ~ 5070mm - Inner Dimension ~ 4960mm (Autark Explorer: EL4960, E4, E5)
Outer width: ~ 2120mm - inner dimensions ~ 2010mm
Outside height: ~ 2130mm - inside height ~ 2020mm
Color: White similar to RAL 9016 - Gelcoat exterior and interior
Different color varnishing, other cabin dimensions and shapes optional
Unterbodenbox:
Heated, fully insulated "water tanker" made of 40mm GRP composite panels,
Light measurement approx. 2400 x 500 x 270mm (dimensions may differ depending on floor plan)
Middle in the middle frame over Fuso chassis frame
intermediate frame
Steel profiles and steel pipes, welded and hot-dip galvanized,
With plate spring bearing for twisting in the field.
Flexible screw connection to original bodywork from the Fuso Canter 4x4
entrance door
1850 x 600mm light passage measurement ~ 1800 x 550mm
Aluminum frame with gasket
Insulated filling made of GRP composite panel 30mm
Stainless steel door handle.
GRP handle recess with PUR outer backrest
3-way locking with BKS locking cylinder, foldable cylinder cover
front steps
Extendable with large, non-slip treads
2x storage spaces
Insulated filling made of GRP composite panels 30mm
Stainless steel flap holder.
For valve sizes, see individual floor plan variants
BKS lock with 3-point lock, same as entrance doors
Through the cab
2x doors, of which one to the driver's cab, one in the residential construction
As well as other door and storage space locks
Light passage dimension ~ H = 1000 x W = 500mm
window
Seitz S4-frame window with double-acrylic glass pane, extendable
Inside insect protection and dimming roller blind
For window sizes, see individual floor plan variants
ESG (safety glass) Double - pane insulating glazing optional
skylights
Seitz Mini- Heki 400 x 400mm
Adjustable roof box with double acrylic glass
ground
Functional floor, underheated, in walking area
Platform in seating group
Robust plastic floor covering - selectable decors from Woelcke collection
furniture
Laminate-coated light-wood furniture with decor: Danube beech
Edges with 2mm plastic glued-on edge and machined radius
Push button lock with push button and Rossette - matt nickel finish (stainless steel look)
High quality fittings, on cupboards and flap cups.
Drawer guides with ball-bearing full extensions
Other surface decors and real wood veneer furniture construction optional
upholstery
Selectable, robust and color-coordinated upholstery fabrics from our collection.
High-quality cold foam cushion with thick padding for comfortable sitting.
Pleasant slanting back upholstery on all seats.
beds
Cold foam mattress on Froly comfort sleeping system.
Light height of mattress top edge to ceiling ~ 800mm
Hanging cabinets at the feet.
Wardrobe / fridge
In comfortable height 110ltr. Compressor refrigerator with ~ 7,9ltr.Frosterfach
Including closet for hanging clothes
kitchen
Worktop with scratch-resistant, robust CPL coating. Working height 960mm.
3-burner cooker, including cutlery drawer and staufach behind door-optional oven
Round sink ~ Ø 400mm with single lever mixer
Including Staufach with 2x shelves behind the door
Between cooking hob and sink 4x drawers with different heights (E3, E4, E5)
Foldable worktop on the right of the kitchen block (E2)
Hanging cabinets over kitchen, clear dimensions: H ~ 260mm, T ~ 260mm
wet
Shower tray made of household or made of stainless steel with 4x drains
Washbasin with stainless steel washbasin, single lever mixer,
Including a cabinet with 2x shelves behind the door
Bathroom cabinet with 4 shelves for bathroom utensils.
Thetford toilet with onboard water connection
Removable drawer with external flap
Optional other toilets
Heating / boiler combination
Diesel-powered 6KW recirculated central heating with integrated 10 ltr. Hot water boiler.
Multiple heating outlets with manually adjustable blow-out nozzles.
Underheating function floor
Water system:
Cleaning opening, drain valve / tap 40mm, vent, external filler neck lockable
Fresh water tank approx. 200 ltr with drain wall (optional expandable) Filler can be locked
Pressurized water system, in front coarse filter / prefilter with stainless steel strainer
Waste water tank approx. 90 ltr. (Optionally expandable)
gas plant
1x 11kg gas bottle (cooking) regulator system pressure 30mbar, gas test, test book, plaque.
Electrical:
On-board battery - maintenance-free ~ 160 Ah lithium
Charging starter batteries - Onboard batteries in driving mode via charging booster 12V / 45A -Li
CEE supply with 230V with adapter cable. FI circuit breaker
Automatic charger 230V-12V - Li
2x 230 V sockets (installation location by arrangement).
2x 12V fuse links
1x 12V socket outlet
Infopanel for water tank and battery capacities.
Main switch for 12V system and water pump
Lighting with LED, light color warm white
6x LED ceiling lights
4x LED reading lights, swiveling
2x LED storage space lighting
Electrically expandable
Solar system 2x 100W, walk-on, with charger
TÜV approval for the special motor vehicle camper, letter, instruction, handover
dhackney
Basic price Woelcke - Autark "Explorer"
Short wheelbase: (3415mm)
Total length ~ 6370mm, total width ~ 2120mm, total height ~ 3390mm
EL 4460 - Basic vehicle + Leerkofferaufbau 103.200, - €
Incl. Entrance door,
front steps
3-D roof and side spoiler, intermediate frame, underfloor box
(Build-up price for base vehicle delivered 52.200, -)
E2 - Basic vehicle + set-up and removal (as described) 148.800, - €
(Build-up price with basic vehicle delivered: 97,800, -)
E3 - Basic vehicle + set-up and removal (as described) 150.400, - €
(Build-up price with basic vehicle delivered: 99,400, -)
Long wheelbase (3865mm)
Total length ~ 6870mm, total width ~ 2120mm, total height ~ 3390mm
EL 4960 - Basic vehicle + Leerkofferaufbau 107.800, - €
front steps
(Build-up price with basic vehicle 56.300 delivered)
E4 - basic vehicle + set-up and removal (as described) 160.900, - €
(Build-up price with basic vehicle delivered: 109,400, -)
E5 - Basic vehicle + set-up and removal (as described) 158.600, - €
(Build-up price with basic vehicle delivered: 107,100, -)
Prices incl. 19% VAT. , VorFracht, TÜV, letter from the company Woelcke - 71296 Heimsheim
Price list valid from 04/2017
Special equipment Basic vehicle Woelcke - Autark "Explorer"
Base vehicle:
Passenger comfort swing seat with horizontal suspension and armrest 2.980, - €
Automatic climate control 2.260, - €
Batteries, 2x 12V / 100Ah, maintenance free 220, - €
Protection cover for Ad-Blue-Tank 380, - €
Cruise control 1.650, - €
12V, 13-pole, plug-in socket, Fuso
Ball-head trailer coupling + 12V electric set 890, - €
Fire extinguisher ABC, 6kg, in the driver's cabin 260, - €
Finish: silver metallic 740, - €
Painting: cherry red or beige (other colors on request) 620, - €
Main tank ~ 170 ltr 2.160, - €
Radio CD with Bluetooth function 400, - €
Navigation - Radio / CD - Reverse camera - I-Pod / -I-Phone
Multimediaentertainment, double-Din in the driver's cabin 2.940, - €
Equipment package 1 "Poor-Road" = single tire
5x single tires 285 / 70R19,5 M + S - Tires with spare wheel 285 / 70R19,5 12.550, - €
Cabin roof rack with branch protection rail and 3x aluminum box, lures 970, - €
Motor underrun protection under bumper
In the direction of the front axle, welded, adapted steel profiles / tubes
And an edged aluminum plate 1.400, - €
Compressor (12V)
With 6ltr. Steel air tank,
Spiral hose with filling valve and manometer for filling the tires,
Firmly installed and with one compressed air connection right and left in the cabin 1.440, - €
Winch with 12V connection
25m winch cable running in reel window, front mounted, traction force 5.1 to 4.240, - €
Rear underrun protection, foldable, hot galvanized 940, - €
Towing hook front, 2x hot galvanized 360, - €
jimbol
Wow
Am I reading that right, that a complete living unit and chassis, already installed are about 150k euros? That seems really cheap for what appears to be a high quality camper.
vertical.dan
