Suggest a single burner propane stove?
CADAC Safari Chef Lightweight Gas BBQ
https://www.amazon.com/CADAC-Safari-Chef-Lightweight-Gas/dp/B002JTQ25W
Yeah I thought so at first too but once you start using it you find uses for the accessories :chef:
And those middle 2 pieces between the grill and lid are really just 1 piece thats included, flat on one side griddle on the other and they are showing it in both configurations so..
I also have a folding 2 burner Partner Stove that I split into two single burner stoves........ definitely rugged!
http://partnersteel.com/LG01.htm
Hi Dennis,
I'm considering that Partner two burner stove. How easy is it to use as a single burner stove when split? Does it need two hoses/tank connections when you are using both burners? Also, it looks like the propane hose connection(s) comes out the front, which seems to make no sense and be a major trip/yank off the table hazard -- is that rally the case, or am I way off base?
Thanks,
Jeff
The Gas One dual fuel stove is nice and comes with a carrying case. I have one of these:
https://www.amazon.com/GS-3400P-Por...=1489940072&sr=8-2&keywords=PROPANE+DUAL+FUEL
I have a Stansport version of that from a few years back and I love it. It has never failed to light on the first twist of the wrist, and the super-easy light makes getting coffee going 1st thing in the morning much easier. It also has better heat control that some of the other camp stoves, so I don't have to work so hard to avoid burning my eggs.
Thanks for that. It is really hard to find a high quality single burner propane stove. I'm not interested in another butane stove; I already have one at my cabin for emergencies. It seems the Gas One and Stansport are no longer available, but I found this one that seems like a decent option, though I'm concerned about the cheapness factor...
http://www.homedepot.com/p/Sportsman-Single-Burner-Camping-Stove-801439/206403603
My preference would be a Partner, but that would mean using half of the detachable folding two burner, but in effect I'd be paying almost $300 for the one burner I need :(
The Amazon reviews are pretty bad.
https://www.amazon.com/Sportsman-Si...=2025&creative=165953&creativeASIN=B014F13LSC
Hi Dennis,
Thanks,
Jeff
Hey Jeff-
When split each burner requires a hose and fuel source..... you could rig up a Y-type hose I guess to use both at the same time.
I turn the stove sideways so the hose connection and adjustment knob is on the side.
I only use one burner..... gave the other burner to a friend..... definitely a rugged single burner stove!
Dennis
The other option for a single-burner propane solution is one of the (many) that is meant to be threaded onto a 1-lb bottle. I like to use bulk tanks and wanted a more stable platform than balancing on top of the bottle, so I cut a hole in an aluminum plate and have a removable mount on the side of my chuck box:
bmYNWlJx3IE3lyDpD-poE0Ot73GPIW4w38RI9EGXyn8CVrfImcg0lH681EiGyIZOpOlA1AFpmcMUkHW3CUXQ2iNQUHcFeAtMxRZqmekZgbkuY1VGWH_zy0YlEGL_FanaK0XYZBYm1Yw6XeJS9uRRps8sI9jXIny3-lr9-c4vh2TW7gB0R1ggQaIwiga0zVDcMt0Mqh3n4w7dI8ejKic4mza2AKebVsfUGA7BB_PdlEqvaiYNfkxhxnLe1hL-S1vrUogSnf0ajYs1XguSCPM0hO0aFiaTuUZEp5s8ALARwiiOvqD7X1_rOQ8AB7lhCmeXkIzkk0MwjcQ3_GzL-eM3tTVxp3F00_u3ngrA6ErElYwZ_nP_afZBYmaGlnAA11UdUowKcRtnWHLwRvNlcapty6JlUoKjlV8fvuKokKAP_n6GucUtXGmvRB4nTQaZwZ3gJAHRlbIOSjOibI_npIRq_DcunAqF7pHQFRcmLGObORG88ZQY-ix8GCPdB2omqZ-tRYIkzbj7FRuFUnL4JLBguveW4ahfbdTxZw45_E1yLkQVJOwfD_s9Emau1VqH8ZVUL4yfuRrjZNaJpBx_bedtY7XWQpUvTeuEnsQ1h83TSNXJp9WzFzDh5E5G8bPm8o3lxK6MNSeHAixnyLLXCfjOU_fur1hFvscZlV5_=w600
I don't typically carry a "tree", and I like having two different fuel types (for redundancy), so I use this little chuckbox burner most of the time, and use the butane burner when I need a 2nd one or when the propane is being used to run the skottle or big turkey-fryer burner.
Try calling Partner Steel directly, they've accommodated special requests for me in the past. Half a stove should be no problem.
A big thanks for the responses and suggestions everyone!
I emailed Partner a while ago and they gave me the info I need on using just one burner. Just yesterday I asked them about a custom order for one burner, so I will see what they say.
@Herbie, that is a great idea. I might look into something like that as an alternative. I have been thinking about how to rig a single burner that I can clamp onto a table or trailer fender. One thought was to get something like this, cut off the fabric, drill vertical holes in the frame, and use bolts and wing nuts to attach a stove. It folds flat, is light and compact, and should be fairly strong.
https://www.amazon.com/Mountain-Buggy-Clip-Highchair-Lime/dp/B007AAIEDS?th=1
I might even use it with a Partner stove...
Can anyone find a flaws in that plan that I have overlooked? Thanks in advance.
Jlbeats
