Pictures - Starting my 5x8 Cargo Camper Conversion
gwolff
I went a little crazy and added a 2.5" 0.25 thick square tubing from the tongue all the way back to the cross member at the axle (or I guess, axleless suspension). I just want it to be really beefy and the stock tongue just wasn't doing it for me. I think it will be worth its weight.
gwolff
I fastened the fenders to the trailer temporarily to do a fit check. They fit! The tire on the front is not going to stay there... I plan on building a storage box on the front out of tubing with an expanded metal floor. I will mount the tire on top of that so the top of the tire should be flush with the trim where the roof begins.
gwolff
Replaced the bolt on jack on the tongue with a weld on swivel jack. Much better
Took it for it's first ever drive around the block today. My dad tailed me in his truck to act as my brake and turn signals since I do not have any yet.
Then brought it home and welded the fenders on. They look great, they are sturdy enough to stand on. In hindsight, I'd have given the tires a little bit more clearance, but they should be fine.
gwolff
I did some fun stuff yesterday and mounted my awning. I made some brackets and spacers to get the awning up around the trim and above the door.
DsiDan
That Suspension moves a lot more than you would think. Those tires will be rubbing. I stuffered the mistake. Trailer looks bad *** by the way. Love the build.
YaRiteZ71
