Pressurize a camper
Coachgeo
How. Surely opening a door or window would defeat this... Neil
Pressurizing is done to keep "road dust" out of camper box when driving. Some parts of the world this is a must. You start with a clean camper inside and when you get to your destination and open the door..... there is layer of dust everywhere inside the camper. Pressurizing it helps small air leaks have a stream of air escaping that prevents dust from entering. Also helps lower compartments not bring in water during deeper water crossings.
S2DM
Neil
A camper under motion has high and low pressure areas, just like an airplane wing. This tends to suck air out of the camper in some areas and force it in in others, resulting in dust intrusion.
I know a few folks have plugged their cab exhaust into the camper, utilizing the filter aspect of the cabin air system to get clean air into the camper. This obviously has limitations. But it wouldn't be hard to utilize a second of the same pump and filter apparatus to bring fresh, filtered air into the camper when underway.
Victorian
This is certainly an issue with cheaply made trailers and campers. Quality windows/doors and hatches should never let dust in. Another big details that's overseen are opening at the rear wall. The vortex created outback is fairly big and should not be underestimated. Pressurizing could work, but I do not have any practical experience with that.
Cheers
robert
I've seen those but never gave them too much thought. would a plenum holding a filter be installed underneath the vent? and somehow water, driven water at that, would have to be accommodated, no?
I'll be honest, I don't quite understand how they work myself. I know it has to do with the airflow over the camper/shell. They mount them on the top near the front and rear and they're a factory option on many of tehir caps including the ARBs. Here's a thread I found talking about them: http://www.4wdaction.com.au/forum/viewtopic.php?t=148488
Neil
What pressure would you need to keep the dust out and how would you compensate for high altitude say over 4000m . I am at this height now in Argentima and the dust os teal bad so this is an interesting one.
Not sure that its practical to make the cabin completely air tight. I huess if it was then this alone would keep the dust out. Therefore you would need to create more pressure than your losing all the time. This is a challenge.
Sounds like a great idea in theory. How it works on practice i think is another matter.
Good thread
Thanks
Neil
Buliwyf
Viking with a Hammer
There's an intense + pressure wave at the nose of the trailer. A simple filtered air inlet there would do the trick.
Same reason your AC in vent is at the bottom of your windshield, and not on the fender.
On my older Ford F250, the bed liner would get air under it's rear and inflate and start to lift out. On my work truck, I can see my rear doors (Reading box) get pulled open an inch, on my rear view camera.
s.e.charles
this might be someone's next great invention:
remember the bottle generators for your bicycle headlight? it had a knurled wheel which could be flipped against the tire sidewall to make juice. why not a similar gadget for a trailer fan? when the tires were revolving, fan speed would be governed x rpms. not many parts to break or be serviced - all mechanical.
robert
I've actually seen some pictures of a rotating fan on some Aussie caravans (campers) but I can't find any examples right now. It had a fan that was parallel to the roof and spun as the air flowed over the top of the vehicle/trailer combo.
bradbarbz
