GXV Global Traveler for Sale
stefin
All-
We are selling our GXV Global Traveler to take on new adventures. We have loved the truck, and taken some great trips. Most recently the family (4 of us) traveled through CO-UT-WY-MT-ID-WA-OR-ID-WY-CO over 40 days on as much dirt as possible. Asking price is $165K, which will include new tires (currently ~50%)and AGM house batteries. Serious inquires are welcome.
The truck is currently in South East CO, but may be heading to the Northeast soon. The box is a 2012 GXV built on a very clean low mileage 1988 Mercedes 1017. I will add exact mileage to this post shortly, but its under 30K. I've had "Big Daddy" for a little over two years after purchasing nearly new through Global Expedition Vehicles, who offer great support if needed (thankfully we haven't needed much, other than figuring out how things worked). I've attached some pictures, and have more if anyone has any specific questions. Below is a list of specs. Most recently I added pyro/boost/volt/trans temp/trnsfr case temp/fuel1/fuel2/fuel3 gauges in a custom housing on the dash, upgraded to a high output alternator and installed a 24V-12V converter for in-cab 12V, and LED offroad lights. I also installed 1 and 2 layers of Dynamat behind the cab interior. The cab seats 2, and there are bench seats in the back with seat belts for 2 more. The kitchen table slides down for a second bed, and we have a removable bunk that quickly installs above it for a "cot" type 3rd bed. I typically get between 8-11 mpg, depending on where we are and how we are travelling. Range with full fuel is around 1500-2000 miles. Top speed is 62 mph, and it crawls well in low range. Full time all wheel drive, with locking rear and center diff. It does not have CIS, we use the truck air and a hose to pressure up or down as terrain requires. We have found the truck to be (surprisingly?) very drive-able with nice tight steering/tracking and easy shifting. It has been supremely reliable.
Thanks for looking,
Steve
Specs:
GLOBAL TRAVELER
BODY SPECIFICATIONS
• Width: 8’
• Length: 17’ 6”
• Int. Height: 6’ 6”
• Overall length 23.5'
• Height 12'9" (top of air conditioner on body)
• Integrated Entry Door w/ Window
• Doors include a 3 point lock system
• Seitz Dual-Pane Acrylic Windows - Qty. 5
• Dometic Skylights, Qty. 3
• Natura Opening Wall Panel
• Oversized Storage compartment accessible by 4'x4' doors on the left & right at the rear. Full 8’ width storage area
• Cab to cabin access
GALLEY/DINING
• Alder Wood
• Stainless Steel Sink
• Webasto Diesel Cook top
• 2 Drawer Stainless Steel Refrigerator/Freezer
• Slide-out Pantry
• Microwave/Convection Oven
• Dining Booth Converts to Aux Sleeping Area
BED AREA
• Premium Queen Mattress
WASH ROOM
• Wet Bath w/Stainless Steel Sink & Shower
• Thetford Cassette Toilet
• Teak Medicine Cabinet w/Mirror
• Teak Counter
ELECTRICAL
• Marine Grade Wiring & Components
• Controls for Systems Management & Monitoring
• Fischer Panda AGT-PV4000 - 4 kW Diesel Generator with Kubota EA-300 diesel marine engine and MPL sound shield (>50hrs of use)
• 12v with 120v Systems with Shore Power Connections
• 765 Ah AGM batteries
• Voltage Inverter: 120v
• Solar Panels: High Efficiency 180 Watt PV Module, Qty. 2
• Automatic Circuit Breakers for all 12v DC & AC Circuits
• Marine Grade Cabin Lighting, energy efficient LED
• Flexible Arm LED Reading Lights
• Wall mounted LCD HD TV with Powered Antenna
• Mobile TV/Video System: CD/ DVD/AM/FM,, SD Card, Mp3
• LED Exterior Work Lights - Right side, Qty. 2
HVAC
• Webasto EVO Air Heater with High Altitude Control
• Webasto Hydronic Thermo-90 Coolant Heater plumbed for hot water and to preheat engine
• 13,000 BTU Air Conditioner
• Fantastic Vent #6600 with Remote Control
WATER SUPPLY/PLUMBING
• 125 Gallon Fresh Water tank
• 32 Gallon Gray Water tank
• Stainless Steel Indel Marine hot water heater
• All plumbing is installed within the cabin envelope, so there is no exposure to outside temperature
• Water Filtration system
• Exterior Shower - Hot & Cold
CHASSIS
• ~30,000km (will update as soon as I can)
• Mercedes 1017 - 4x4
• Wheelbase: 143”
• GVW - 26,840
• Curb weight with fuel, water and gear- 24,500
• Diesel Capacity: 200 gallons
• Tires: Michelin XZL 365/85
R20 + Matching Spare (we can put 395R20s on it next, which will move top speed to about 65mph)
ENGINE
• 6 cylinder, type OM 352 A V, 364 cu, in., Turbocharged
• Horsepower: 168 @ 2800 RPM
• Diesel - High or Low Sulfur, Bio-diesel
TRANSMISSION / DRIVELINE
• Transmission - 5 speed
• Transfer Case: 2 Speed high-low, VG 500-3
• All wheel drive with locking center and rear differential
• Brakes: Hydraulic, dual circuit
stefin
All-Here are some more pictures, hope I'm adding them to this thread the best way. I'm realizing I have a bunch of outside shots with cool scenery, but not a ton of detailed inside pictures. The spec sheet has a floor plan if you are interested. As soon as I can I'll post more detail pics but this should help some. Current plan is to drive from CO to Western NY the week of October 15.
  • #102-Global Traveler Specs.pdf
stefin
All,
Additional inside and detailed pictures of the rig. The truck is currently in La Junta, CO. In earlier pictures there are big loading ramps on the back. These were originally intended to load a 4 wheeler or motorcycle into the garage. While possible, I deemed it risky and impractical. I carried my dirtbike on the front. I have remove the ramps and recommend some simple fab or bolting on brackets/holders for the included sand ladders, propane tank for outdoor grill, and shovel.
Thanks for your interest!
Steve
stefin
...And a few more
lactic
How big is the back garage? If it was designed to hold an ATV or motorcycle, I assume it will hold 2-3 bikes and/or skis? Wheels on? Thanks! Great rig!
stefin
Thanks lactic. It all depends on what else you have back there, but there is room for a bunch of bikes with wheels on if you want to use the space for it. I've had ~8 big black and yellow totes strapped down (using cargo track mounted to floor), a grill and an outdoor cookstove, camp chairs etc. etc. plus 3 pairs of skis and two bikes back there at the same time, and there was still room for more. Front wheels off but I'm not sure I had to. It's a straight through unobstructed 4'x4'x8' with big swing up doors on both sides. The actual space is bigger than that by half a foot or so in height and width, but those are the door dimensions. The bed is movable and will go up to get another foot or two of height inside if needed. I don't prefer that because you end up screwing around when you want to sleep, or sleeping with only a couple feet of headroom. I carry my dirtbike up front on a stout receiver tray and I've hung a few bikes off of that before.
Hi Steve I tried to send you a PM but not sure if it worked. A good friend of mine is interested. Serious buyer. Can you please email shoot me a PM with your contact info and I will connect you guys. Thanks.
stefin
BeCo, thanks for your interest. I shot you an email, please let me know if you don’t see it.
Explor4
Hi
Just wondering if your truck is still available ?
We are interested in your vehicle. We were wondering if we could meet up with you when you head east to have a look at the truck ? Or if you wanted you would be welcome to stop by and stay here if you wanted. We have lots of room.
Thanks
supermoo
Very nice truck. When you are on the road, have you had to have any services done to it? Just wondering if any truck service shops can work on the engine/trans? I am interested in the truck as we are actively looking at GXV and Earthroamers.
stefin
I've had no problems getting regular fluid and filter changes. I haven't had any mechanical issues to test engine/trans work, but I know its a simple engine and driveline, and the folks I have worked with on the truck have shipped parts all over the place for people in need....but that's the best I can do on that one. The OM352A engine is all over the world, in trucks, generators, ag equipment..... Parts are not a problem.
Please let me know if you have other questions. Thanks for your interest.
Steve
4xCoffee
