Best quality, design, fit + finish, and warranty support in Pop Up Camper?
LosAngeles
Hi all
Been doing a lot of (various) forum(s) reading…. trying to figure out the best pop up camper.
Needs space for 3 people (us parents and our 12 year old kid)
We like to do 3 to 14 day trips, including areas that dip below freezing at night.
Will custom order a Ford F150 SuperCrew with high cargo capacity ordered, 4x4, with 6.5 foot bed. (so lightweight is a big plus)
No we dont want an F250….. the F150 is much nicer. According to Ford - 4x4 F-150 SuperCrew, 156.8” WB, with Heavy-Duty Payload Package and 18" wheels payload is 2,690 LBS.
Been making spread sheets of costs of pop up campers, to compare prices with our preferred options included.
For better or for worse (?) I do prefer the idea of an aluminum frame. I do understand that thermal bridging is a real thing. I also do know that keeping some ventilation going in cold areas will reduce condensation, for sure.
Would love to get an indoor shower for occasional use.
In no particular order: here are the top contenders - all slide in. (can’t go flatbed for a variety of reasons I wont bore you with)
Any thoughts on all of this?
Four Wheel Camper Grandby
advantages: nice fit and finish, and seemingly good quality (?) and holds value well (?)
The clever optional indoor shower on the Grandby does not take up any room when not in use. It is a curtain and a floor drain. The curtain goes all the way into the floor drain to contain the water.
disadvantages:
to get King North South bed you have to pay $600 extra to get the flush stove and sink (ouch) plus an extra fee for the slide out bed extension. Would prefer to sleep North South
Also seems to be a bit more expensive for vaguely similar campers from competitors such as All Terrain Campers.
Seemingly less willing to do any customization at build. (such as extra insulation)
All Terrain Campers:
Supposedly good quality, with somewhat less nice interior (as compared to Four Wheel Camper)
I spoke with someone at All Terrain Campers about a few reasonably intelligent questions I had, and the person I spoke with was very ‘cold’ and not helpful. It put me off a bit.
Overland EX
supposedly better than most other pop up campers in cold and wet - due to walls being made from composite panels without any thermal bridges and the soft sides are 1 inch insulated canvas developed for tents used in the arctic.
However the interior is unbelievably spartan, and also long term support and any warranty repairs are a big concern.
Phoenix pop up camper
could be ordered with extra insulation in the floors, pop up, walls and roof…. and with ”Winter Grade Curtains”.... a heavy rubber backed fabric.
8.5’ Caribou Lite by Outfitter with inside shower.
Advantages:
Very lightweight
Fiberglass exterior would likely thermal bridge a bit less cold into interior (perhaps lead to slightly less condensation)
About $2,500 - $3,500 less for a vaguely similarly equipped pop up trailer compared to FWD Grandby.
Disadvantages:
the indoor shower eats up space even when not using it.
and….
I recently found a forum thread from about 2012 that had various people with very negative comments about Outfitter having poor quality and poor warranty support. (Can’t find it right now)
Perhaps that has changed? Any current info?
Between these manufacturers - what do people think is best quality overall?
Thanks!
Runt
Phoenix campers all the way! They will actually support and help you after the sale. I don't mean just fix what was warranty but for example, I did not drain my tank less heater properly, I inquire on details about the heater, no problem Cari hooks me up with a great price and was exactly what fit. Oh how about catching a corner o my camper on the corrugated roofing on a Save On Foods shopping Cart shack. No problem, here is what you do. Or Rob I kind of want a taller pop up...no problem....we can do that when works for you? They make awesome campers with all the best parts, they stand behind there work, there super nice people and did I say they make great campers built exactly how you want! I spent a lot of time researching my campers and no one else is like Phoenix.
LosAngeles
thanks. have read a lot of great things about Phoenix, and nothing bad.
How was the cost, roughly, compared to the others?
thanks
Runt
thanks
Hard to compare because the options I spec'ed mine with were not available in any other camper. manufactures at the time It was roughly the same price as a FWC if comapred apples to apples so to speak and I did not include the options. My camper has a wet bath and better parts such as solar film instead of the window frame type solar panels, roof rack (3 bar), ladder, ARB fridge instead of a typical 3 way RV fridge, Combo sink / stove under recessed glass instead of separate stove top and sink for the comparable bits. I was able to get the spec. on the camper that worked best for me that no one else offered. I added a generator compartment, extra insulation in floors, walls and roof, a escape/shooting hatch over the bed, extra insulation, winter grade insulation drapes, rhino lined flooring, 20,000 btu furnace, insulation on tanks and lines with heat tape, easy access compartments with flush mount latches, 30 lb horizontal propane tank, exterior lighting, color matched to truck, awnings on side and rear and removable top bunk style bed and optional king size dinette sleeping.
hemifoot
if you weren't set on aluminum i could highly recommend a northstar.hard ,if not impossible,to find a few negative comments about them.
Check out Hallmark, definitely not the cheapest but when you compare comparable options to what they come with standard you'll find they're about the same.
Composite sides, very well insulated for a pop up. Have never had any condensation problems even on the Oregon coast.
Built to order so you can make adjustments and refinements to fit your needs
Sent from my Pixel 2 XL using Tapatalk
windtraveler
BundutecUSA is, in my opinion, the best value. They offer one of the best customer service experiences of ANY type of company, not just camper companies. They will not only customize but also provide assistance in the design if you want. They build a quality product and provide excellent service.
Eathcruiser GZL is another high end slide in camper but they are not cheap. I have no personal experience so I can’t speak to their customer service but they were very accommodating when I visited their shop.
Sparse Gray Hackle
Morgan Freeman Imposter
My opinion is ATC is the best value, and very well made. Maybe not as fancy as the others, but they’re great to work with and they stand behind their products.
Buliwyf
Viking with a Hammer
Could ya'll mention some rough pricing, when you mention brand names.
A little 6.5' box with a little cab overhang, and a lift roof and tent on top, better be really darn good for $101,000.
craig333
I wonder how many campers could survive falling off on the swansea cerro gordo road and be worse for the experience?
project13support
