cherokee1989
Mainly using this to keep record as I get this thing built. Feel free to chime in with your thoughts and critisizim, positive or negative! This is a lengthy initial post as I've been building it for a few months and need to play catch up. So, here we go!
Well I finally found a rig I feel could do it all. Picked up a 2006 Ford E350 Turtle Top Van Terra down in Pueblo, CO a few months ago. Have grand plans of creating it into the Fab Lab "Battle Bus" twin brother, of course that's a ways down the road. Anyways, I've mainly been focusing on getting the inside gutted and insulated so I can get it registered and insured as an RV as soon as possible. Before I get too far into why I chose this over an econoline here's some pics!
Specs:
Issues:
). The PO was super nice and for only $5500 I couldn't complain too much. I tried to contain my excitement during the whole transaction, but of course resistance was futile. I could barely find equivalent year and mileage V10 E350s for that much, and now I didn't have to worry about adding a camper top!
Well enough rambling, here's some more pics of what I've done so far. As I mentioned before, I'm getting the interior converted for registration and insurance purposes. So far I've gutted the whole thing:
You can see in those pics that I've added some insulation in already. So far the 1" insulation board has been working perfectly for the metal frame. I've been using that fiberglass insulation for the ceiling as it's super awkward angling.
I've ran into a few issues and things that have needed fixing along the way:
This is how the insulation is looking for the ceiling.
Added a layer of reflectix and duct tape, then attached furring strips to the metal frame for attaching the finished ceiling.
...continue to next post vvvvv
Specs:
- 2006 Ford E350 Cutaway
- Turtle Top Vanterra Conversion
- 135000 miles
- 6.8L V10
- 5 Speed Trans
- Dana 70 DRW axle with 4.10 gears
- Hideous red seats
- Old 12V VCR TV
- 2WD (for now
Issues:
- Looks like PO hit curb on the large passenger door area. Fiberglass is a bit chewed up but not bad.
- Main side door motor isn't working. So in order to keep it from flapping open the PO jerry rigged a hook latch to keep it closed. Not too worried as I'll be removing the whole thing anyways and mounting an actual RV door in its place
- Some body work on the front passenger fender. Possibly involved in fender bender or something.
- ENTIRE suspension, front and rear, is shot! The thing rides like it's on bricks. That's where Chris at Ujoint will come in though!
- The windows were poorly sealed from the factory and after 10+ years of leaking, water damage had developed in areas of the floor and a few rust spots. So I removed each window, resealed with butyl tape, then recaulked around the entire exterior of the windows. Should be water tight now.
- Now I needed to cut out the sections of floor damaged by the water. Simple enough, just cut and replace with new plywood, treat it and seal it. Hopefully that'll do the trick.
- Then there's an ungodly amount of wires everywhere from all the dome lights, speakers, auxiliary switches, blah, blah, blah. It's all going and getting a clean start
