void loop()
  // Declarations
  byte cPort, cTxPort;
  long lMsgID;
  bool bExtendedFormat;
  byte cData[8];
  byte bData[4];
  byte cDataLen;
  int lowrange = false;
  unsigned short wSpeedL;
  unsigned short wSpeedR;
  unsigned short wSpeedA;
  unsigned long previousMillis = 0;
  unsigned long Pinterval = 1000;
  //Serial printing interval
  bool SERIAL_OUTPUT = true;
  // Start timer for LED indicators
  TimerStart(&pTimerLEDs, TIMER_RATE_LED_BLINK);
  while (1) // Endless loop
    // Control LED status according to CAN traffic
    LEDControl();
    //Read low range switch and assign to lowrange varaible
    //lowrange = digitalRead(LRSW);
    //Serial Print Interval
    if ( SERIAL_DEBUG = true)
      unsigned long currentMillis = millis();
      if ((currentMillis - previousMillis) >= Pinterval)
        // save the last time Serial Printing Occured
        previousMillis = currentMillis;
        // Set Print to serial
      }// end if
      else (SERIAL_OUTPUT = false);
    }//end if
    // Check for received CAN messages
    for (cPort = 0; cPort <= 1; cPort++)
      // removed lowrange == true
      if (canRx(cPort, &lMsgID, &bExtendedFormat, &cData[0], &cDataLen) == CAN_OK  )
        // Scan through the mapping list, If frame matches ID
        for (int nIndex = 0; nIndex < nMappingEntries; nIndex++)
          if (lMsgID == CAN_DataMapping[nIndex].lReceivingMsgID)
            // Removed matching for source CAN port
            // && cPort == CAN_DataMapping[nIndex].cReceivingPort
            if (SERIAL_OUTPUT)
              Serial.print("cPort");
              Serial.print("\t");
              Serial.print("lMsgID");
              Serial.print("\t");
              Serial.println("cData [4]..[7]");
              Serial.print(cPort);
              Serial.print("\t");
              Serial.print(lMsgID, HEX);
              Serial.print("\t");
              for (int mIndex = 4; mIndex <= 7; mIndex++)
                Serial.print(cData[mIndex], HEX);
                Serial.print(":");
              }//end for loop
              Serial.println();
            //If recieved port is CAN0, transmit on CAN1, otherwise transmit on CAN0.
            cTxPort = 0;
            if (cPort == 0) cTxPort = 1;
            //Initialize wheel speed int to zero
            wSpeedL = 0;
            wSpeedR = 0;
            wSpeedA = 0;
            //copy speed data bytes to working array from CAN data array
            bData[0] = cData[5];
            bData[1] = cData[4];
            bData[2] = cData[7];
            bData[3] = cData[6];
            //Set wSpeed to array data
            wSpeedR = (wSpeedL  << 8) + bData[0];
            wSpeedR = (wSpeedL  << 8) + bData[1];
            wSpeedL = (wSpeedR  << 8) + bData[2];
            wSpeedL = (wSpeedR  << 8) + bData[3];
            //print data for debug
            if (SERIAL_OUTPUT)
              Serial.print("wSpeedL raw");
              Serial.print("\t");
              Serial.println("wSpeedR raw");
              Serial.print(wSpeedL);
              Serial.print("\t");
              Serial.println(wSpeedR);
            //For Front wheels, frame 0x200, adjust front wheel average speed.
            if (lMsgID == 0x200)
              // copy speed data to wSpeedA
              wSpeedA = (wSpeedA  << 8) + cData[3];
              wSpeedA = (wSpeedA  << 8) + cData[2];
              //debug printing
              //if (SERIAL_OUTPUT)
              //  Serial.println("Front average speed CAN Raw, cData[2]..[3] wSpeedA  ");
              //  Serial.print(cData[2], HEX);
              //  Serial.print(":");
              //  Serial.print(cData[3], HEX);
              //   Serial.println(wSpeedA);
              //divide average speed by 2.73 using binary scale factor,  ((1/2.73)*4096) = 1500
              wSpeedA = ((wSpeedA * 1500) >> 12);
              if (SERIAL_OUTPUT)
                Serial.print("wSpeedA divided = ");
              }//end If
              //Copy revised speed to data array
              // memcpy ((byte*)cData[2], (byte*) & (wSpeedA), sizeof(wSpeedA));
              cData[2] = highByte(wSpeedA);
              cData[3] = lowByte(wSpeedA);
              if (SERIAL_OUTPUT)
                Serial.println("Front average speed Converted Raw, cData[2]..[3]");
                Serial.print("\t");
                Serial.println(cData[3], HEX);
            } //end if
            //Divide Wheel speeds by 2.73 using binary scale factor,  ((1/2.73)*4096) = 1500
            wSpeedL = ((wSpeedL * 1500) >> 12);
            wSpeedR = ((wSpeedR * 1500) >> 12);
           if (SERIAL_OUTPUT)
            Serial.println();
            Serial.print("wSpeedL divided, wSpeedR divided ");
            Serial.print("\t");
              }//end If
            //Copy wSpeedL and wSpeedR to working array, Note offset for start byte.  Assumes both CAN frame and chip are little endian
            // memcpy( (byte*)bData[0], (byte*) & (wSpeedL), sizeof(wSpeedL));
            //memcpy( (byte*)bData[2], (byte*) & (wSpeedR), sizeof(wSpeedR));
            bData[0] = highByte(wSpeedL);
            bData[1] = lowByte(wSpeedL);
            bData[2] = highByte(wSpeedL);
            bData[3] = lowByte(wSpeedL);
            //Print working array contents
            if (SERIAL_OUTPUT)
              Serial.println("bData[0]..[3]");
              for (int mIndex = 0; mIndex <= 3; mIndex++)
                Serial.print(bData[mIndex], HEX);
                Serial.print(":");
              }//end for loop
              Serial.println();
            }//end If
            //Copy bData to data array
            cData[5] = bData[0];
            cData[4] = bData[1];
            cData[7] = bData[2];
            cData[6] = bData[3];
            // Transmit Frame, print error message if CAN_ERROR is returned
            if (canTx(cTxPort, lMsgID, bExtendedFormat, &cData[0], cDataLen) == CAN_ERROR)
              Serial.println("Transmision Error2.");
              Serial.print(cTxPort);
              Serial.print("\t");
              Serial.print("\t");
              Serial.print(bExtendedFormat);
              Serial.print("\t");
              for (int mIndex = 0; mIndex < cDataLen; mIndex++)
                Serial.print(":");
              Serial.print("\t");
              Serial.println(cDataLen);
          } //end if
          //Transmit Frames If low range is not active, or for non-matching frames
          else
            cTxPort = 0;
              if (lMsgID == 0x200 || lMsgID == 0x208)
                //Serial.println("Transmision Error1.");
                Serial.print("\t");
                Serial.print("\t");
                Serial.print("\t");
                  Serial.print(":");
                Serial.print("\t");
          }// end if else
        }// end for
      }// end if
    }// end for
  } //end while
} //end loop
