shade
Gypsum?Wet Sandstone?
Gypsum?
Question 1: That's not what I said.Why do you believe that the owner of the truck is claiming that this just happened driving down a smooth road? What kind of analysis have you done to determine that newer truck frames are weaker than those designed years ago?
Hmmm ... maybe Wonder Bread, but certainly not a baguette.Stale Bread?
Maybe so, but my point has to do with the load ratings, too. I think some of the numbers being issued for today's trucks are rather ambitious.F250-550 Fords have way stronger frames than in the past. I think the 150 is getting a bit porky as well.
Tongue weight had something to do with it, as did the terrain, speed, length of drawbar, lack of trailer brakes, sloshing liquids, and probably some other things.I feel for the guy. If it had happened to me I'd be furious too. We had been considering a Colorado and now, we aren't.
So, the fellow was pulling a 2100 lbs. trailer with nearly 400 lbs. of tongue weight (if I recall correctly). Doesn't that seem like a lot of tongue weight? I would have tried like hell to get the tongue down to 10% of total weight. Do yall think that had anything to do with the frame failure?
I haven't towed anything with that much tongue weight in any rig and am genuinely curious.
That's a great article. Thanks!This is a good article on bent “utes” while off road with a trailer. Apparently it affects many brands, even the holy grail of down under trucks: Toyota.
What causes a bent chassis and how to prevent it
What causes a ute chassis to bend? Ron Moon slips under the bodywork to discover the cause of chassis failure.www.whichcar.com.au
If you can jump the truck 4ft in the air, or tow 5,000 lb down the road ...
