Waking up in Oregon, the first thing I did was to fill up my gas tank, and then get some breakfast. I briefly forgot that it's a crime to pump your own gas in this state. Fortunately, the law has changed so that remote areas are allowed to let you pump your own gas. But it's up to the station. This would be only one of two times I would be allowed to pump my own gas in Oregon. The other times I would have to wait impatiently.
(How Oregon thinks I pump my gas)
If you ever do the Trans America Trail, get use to this sight.
I had to stop and take a few photos of this lake...
How many cows do you see?
The Gate!
Everything was going great until I came to this fence / gate.
The TAT follows Willow Creek Road, crosses US 26, and becomes Rose Creek Road. The TAT eventually makes a right turn off of Rose Creek Road, and goes north in to the Malheur National Forest on NF-16. It was at this point I ran across this gate made out of wire fence. The end fence post in the gate was stuck in a wire loop at the top and bottom, and there was a piece of wood with wire on it wrapped in the middle to hold it closed. I probably could have got it open, but I wasn't so sure that I could get it closed by myself.
My Gaia GPS app wasn't getting a signal, so I was following a line on a screen, and my factory Ford navigation wouldn't show me any detail if I zoomed out. It appeared that Rose Creek Road continued on, and with it starting to rain, I chose to continue and bypass this gate.
The road I was on went a couple of miles, and basically ended at a ranchers home. I got out and talked to the guy for about 15-minutes, and explained the gate I had came across, and how I ended up at his place. He told me that the gate was on a forest road, and that I had the right to use it if I wanted. He even offered some instructions on how to open it (it was not his gate).
He suggested that some ranchers may try to keep people out of the area when they put up gates, and I believe the rancher in question chose to build this style gate to look like a fence, and try to deter people from going past it.
The rancher offered to let me use a private road that he shared with another rancher. The road offered some beautiful scenery, but it wasn't the Trans America Trail. The road took me all the way down to US 20, and then I had to follow that west to US 395, and back north to reconnect with the TAT. By the time I was reconnected, I lost about 2-hours.
I would suggest that anyone doing the TAT bypass this spot so they don't have to deal with this gate.
If you turn right on US 26 instead of crossing on to Rose Creek Road (In Ironside), you can travel about 8.5-miles and connect with E. Camp Creek Road (NFD-1684). It's the blue line on my map. The red line is the TAT route. E. Camp Road (NFD-1684) turns in to NFD-1680, and eventually NF-16 and the TAT. If you follow the TAT on Rose Creek Road, be prepared to open the gate.
Looking back, I really wish I would have opened the gate, and it annoys me that I let a rancher deter me from using a National Forest Road.
But as I said, the private road offered some beautiful views...
Linking back up with the TAT took me back in to the Malheur National Forest west of US 395. In some areas, the roads were wide with smooth gravel. Other sections were rough. At one point, I wasn't sure if the trail I was on would even make it all the way through.
I will warn you that these sections through the National Forests in Oregon are longer and more difficult than you may anticipate. Expect the section from Ironside (US 26) to Priveville (US 26) to take up your whole day.
Unfortunately, the sun was starting to set on me, so I ended up heading south off of the TAT on to CR 380, and taking that in to Prineville. After grabbing some Taco Bell before the lobby closed, I headed west to Redmond, and spent the night in a hotel.
When I first got to Oregon, I could feel that I was getting close to the end of the TAT. But Oregon would prove to be the most challenging section.
Here's an in-cab video highlight of the days trip:
Here's the full story:
Trans America Trail - Thursday June 13th, 2019
