HAF
I have built and tested several types of cabinets for my camper. The range involved all wood, combination of wood and aluminum and wood, aluminum and plastic. I found all to be to heavy. I have also discovered that no mater how much glue and screws one uses, wood seems to loosen up after rough duty.
I have designed and built several cabinets out of all aluminum and find I like it best.
It seems to hold up no matter the shaking its exposed to. Leaving my camper out closed up in the hot sun does not result in a weird smelling camper.
If cutting the pre-formed shapes with a laser, the fits are perfect. Combining the shapes with extruded rails means the entire units goe together without screws. Everything bolts together.
For upper cabinets, I am using stand-offs on bottom side of cabinet. I then attach a "tray" to the stand offs. This gives me room to mount lights and run wires in between bottom side of cabinet and upper side of tray. Future changes or troubleshooting is now simple. I plan on keeping these in bare aluminum (rails are anodized). If I get tiresd of the look, I can always wrap with vinyle to change up the look of my camper.
