Kors Camps
Innate Outdoor Co
I've set in motion a plan to purchase a used Kitfox airplane. The Kitfox is classified as an "Experimental Light Sport" aircraft, seats 2 people + 100lbs of pets & gear and is designed primarily for "Bush Plane" operations out of tight unimproved back-country locations and can routinely take off and land in less than 400 feet of runway. One of the primary reasons I've zoomed in on this particular plane is because the wings fold, which makes it trailerable. For the aviators among you who are bound to ask: Im aiming for a completely built Series 3 or 4 model with 80hp Rotax 912 power, standard wing and the enlarged late-model vertical stabilizer. A big 3 blade prop and tundra tires would be nice. Yes there are cheaper tail draggers out there, but their wings don't fold, I won't be able to legally perform my own maintenance, and storage will cost more than the airplane itself.
The idea here is to hangar the plane at home in an enclosed trailer, tow it to local airports for weekend joy rides and travel around on multi-week "overland" camping trips through the western states where I can legally operate the plane out of remote BLM land and rural country roads. I want to begin planning a budget conscious "Phase One" trailer build that will be fully enclosed and feature tie-down points for the airplane, solar powered ventilation and battery tender, as well as fuel and fresh water storage capability. Future iterations could add equipment storage opportunities which supplement the tow vehicle for longer trips and boondocking and could include provisions for a shower and murphy-bed style sleeping for 4 people. My primary AO would be Washington State, Oregon, Utah, Nevada and Alaska.
Tow vehicle is a 2008 4runner 4.7L 4x4. 7000lbs tow rating, 700lbs hitch weight rating. 12,000lbs GCWR. It's on heavy duty OME suspension and will already be set up with rear airbags, brake controller, Anderson weight distribution hitch, new brakes and bearings, extended mirrors etc. so I have my bases covered in this regard.
I'm looking for advice on which type of trailer platform to build from, which materials would be most thermally and cost efficient, or any other thoughts and personal experience that the expedition community could offer. This will be a slow, multi-year project. I am not in any rush.
Specifications
Minimum Dimensions for Aircraft Storage:
Tandem axles
29" All Terrain tires
Reasonable ground clearance
Under 6000lbs gross loaded trailer weight
Initial Thoughts:
Option 1: Begin with a 8.5' x 24' aluminum flatbed car hauler, upon which a full width 8' 6" wide deck can be added which extends over the wheel arches, creating a "basement" below where fuel, water, house battery and gear can be positioned for optimum hitch weight and center of gravity? The trailer enclosure could be framed with wood or aluminum studs 24" O.C. and plywood sheeting or aluminum-composite/foam panels?
Option 2: Begin with a pre-built high roof car hauler, where "basement" storage would not be an option, thus fuel & water would be stored on the deck in a more forward position, or perhaps along the side walls of the trailer in more expensive, custom storage vessels.
Option 3: Perhaps a open flat deck with "basement storage" below, and a roof top tent mounted up on a raised frame? Or semi-enclosed/perforated side walls that could reduce weight and wind-induced trailer sway that short wheelbase tow vehicles can experience? The drawback would be less weather and debris protection for the airplane and no shelter for camping in bad weather or bear country.
All advice and comments welcome! Thanks! These photographs are examples pulled from google for visual reference.
Specifications
- Length: 23'
- Width: 8' 3"
- Height: 7'
- Aircraft dry weight: ~ 650lbs
- Aircraft fuel capacity: ~ 220lbs or 26 gallons of standard automotive gasoline.
- Target on-board fuel capacity of trailer - 50 gallons or 420lbs
- Target on board fresh water capacity of trailer - 40-50 gallons or 300-400lbs
- Possible grey or black water capacity - 20-30 gallons
- Total estimated payload, without tools, luggage, bicycles, etc. is 2200lbs.
Tandem axles
Initial Thoughts:
