2016 Chevy Silverado LTZ Z71
buellconvert
The third brake light was removed and there was easy 2 ounces of water inside
One of the three bulbs was blown out - likely from heat and moisture
The cavity behind the third brake lenses was pretty damp. I am letting it all dry out overnight
The areas for the two mount screw sure sits at a bad angle and seems to also hold water. No gasket either for the mounting screws.
The gasket for the third brake light is foam - which will absorb and hold moisture
I am using black RTV around the foam gasket area and clear 100% silicon around the lense
Terrible quality. Not pleased
Good to know, I haven't seen any moisture in mine, but I'll definitely be taking a look to see if there's an issue, we get a lot of rain here in North Carolina and I don't need that
Sent from my Moto E (4) Plus using Tapatalk
D45
I don't think a new light housing would do anything
It needs a better seal
The foam gasket is very small and not very thick
Hopefully silicon and RTV does the trick
I have a feeling that the Chevy's aren't the only ones with this problem. Same thing happened to my Dad's 2011 Ram 1500 a year or so ago
D45
I never have had a problem like this on any of my previous trucks
Hopefully it's an easy and permanent fix
phsycle
Tacoma’s and Tundra’s have also had this problem. Luckily, none of mine did.
Don’t tell the Toyota boys though.
tennesseewj
I've definitely seen this problem on other trucks, although usually on older ones when the seal dry-rots.
RTV & silicone will work but seem like a pain to redo every bulb change. Would you be able to use the OEM seal as a template and make one out of a better material instead?
Sent from my Pixel 2 using Tapatalk
D45
The mounting hole design also isn't properly angled. It allows moisture to drain back towards the cab, rather than away from it.
Needs a washer gasket and silicon
D45
I ordered a Injen cold air intake #EVO7103 and also bought a new throttle body that was sent off to be ported and polished
I am very impressed by the Nano filters and know I wanted an oil free filter
The EVO7103 kit uses a #X-1068-BB filter that is huge and will flow a ton of CFM
Flange Inside Dimensions 6.0 ID
Flange Height 1.00
Base Outside Diameter 8.25"
Media Height 7.20
Overall Height 8.50" +/- .150"
Top Outside Dimensions 7.00"
In fact- this is the same filter used on
2001-2004 GM Duramax diesel 6.6L V8 trucks
D45
I like numbers
I believe the 5.3L is an L83 version with a 5800 max rpm
5.3L = 325 cid
Stock throttle body is 78MM?
I believe I found info that the stock TB can handle 780 CFM
325 x 5800 ÷ 3456 = 545 cfm
Pleated K&N filter material will flow 6.03 cfm of air per square inch.
By comparison, a single square inch of the highest flowing paper will allow 4.95 cfm
The freest flowing foam will flow 4.38 cfm
A 5.3L needs 715-757 cfm on the exhaust end
Straight Pipe Flow By Diameter:
5" 2200 CFM
4" 1800 CFM
3.5" 1400 CFM
3" 1200 CFM
2.5" 900 CFM
2.25" 600 CFM
D45
After the TB and air intake are installed......it will be exhaust time
I decided on a Gibson #5656 Dual Sport (exits behind the rear tire) with rectangle or square black tips
  • Tubing Diameter: 3-in./2.25-in.Aluminized mandrel bent tubing.
  • Tip Description: 4in. Polished T304 Stainless Rolled Slash- Cut Tip.
  • Tip Specification: Inlet 2.25 in.; Outlet 4.0 in.; L-12 in.
  • Muffler Description: Baffled & Chambered Design, No internal Packing
  • Muffler Dimension: 4 x 9 x 18 in. Oval Body; 3.00 in. Center Inlet; 2.25 in. Dual Outlet
D45
I see GM also makes a plug and play LED bed light kit
#23295943
#23295942
Whats the diff between the two?
Anyone have this? Bright enough and worth the price?
buellconvert
I don't know what the difference is between the two, might be for different bed sizes, but my truck came with it and I really like it, very bright and you can't even see it under the bed rail so it's completely hidden. I have a tonneau cover on mine and the lights work great to see under the cover, it's timed so you don't need to worry about forgetting that it's on so they don't run your battery down. All in all I am glad I have it...
Sent from my moto e6 using Tapatalk
SoTxAg06
My 19 came stock with the light kit that mounts at the rear of the bed. It’s very handy when unloading stuff at night. I could see it being even more useful with a camper shell or bed cover.
