Nitromethane43
After having the standard air helper bags and being quite dussapointed in the ride loaded and unloaded, I was looking at some alternatives to the double convoluted bags. In the heavy duty truck world the options all come with a huge increase in physical size plus they are rated at very high loads.
The other day I was thinking about trying so automotive options. It seemed the BMW air bags would be easy to Mount and have a rear axle rating of over 3000 lbs with the bags mounted inboard on an a-arm suspension so I would guess they would have a minimum of 2000 lb rating per bag.
They seem to be an easy retrofit on a standard air helper setup, just wondering what are of your thoughts on this. The vehicle is a dodge truck with a Lance camper and weight on the rear axle prior to modifications was 5800 lbs.
