UJOR Build Thread
CaptainBuilt
They make a "hush kit" for that rooftop A/C you have on that van.
How do you have the A/C powered? I'm using a PD4045 under the bed that has a conventer / charger.
CaptainBuilt
What AC unit is that?
Coleman Mach 8.
I have a Dometic Penguin 2:
stevelx450
My 98 Club Wagon Chateau looks so much better! 4" lift, Stage 2 F axle with a hub conversion to 8 on 6.5, 4.10 gears, OX rear, front bumper, roof rack, Pro Comp wheels with Toyo AT3 tires. And.... I've already sold it! We'll rip it further apart tomorrow to complete the 4x4 swap and add some new goodies that the new owner wants.
Hey Chris, what size tires and wheel specs did you install on the chateau?
No rubbing the slider door ?
Looks awesome !
Thanks , steve
ujoint
Supporting Sponsor
Looks awesome !
Thanks , steve
Yes, the door clears 100%. They're 17 x 8.5 Pro Comp wheels., 8 on 6.5 with 255/80/17 Toyo AT3s. No rear spacers.
carnut1969
The van above and the RV both look amazing... but so all of your builds!
I'm most excited to see the ERV build... I'm installing the same kit on my ERV!~
CaptainBuilt
Do you know what transmission comes with the new 7.3L gas? Will the have to be rebuilt or just add on the 4WD coupler?
I'm van hunting lol. Deciding between a 2019 and 2021. All depends on the transmission. It says it has the 6 speed torque shift.
ujoint
Supporting Sponsor
It's the 6R140. The E350 units have to be pulled for an output shaft unfortunately. The 450s don't.
Smudge12
