Ford E350 Diesel 4x4 Full Conversion ***SOLD**
Saline
Hello all! Well I'm done with my side project van so it's up for sale. Originally a bone stock cargo but I took it to another level. This van is an all new conversion, 4x4 and interior. It has never been camped in. Seats 2/sleeps2. Located near Grand Junction, Colorado
2009 Ford E350 EB 6.0L Diesel
170k miles
$74,000 obo
Youtube link for tour:
Engine:
-New Turbo
-New radiator
-New water pump
-New clutch fan
-Blue Spring fuel upgrade
-New 52volt FICM
-Dieselsite coolant filter
-Recent head gaskets
-Recent EGR cooler
-New fuel filters (motorcraft)
-New air filter
-New starting batteries
-5/22 transmission service
-6/15 oil change (motorcraft filter and Rotella full synthetic)
Drivetrain:
-New Timberline Vans 5”4x4 conversion
-Full 7” rear spring packs
Rebuilt Ford D60 front
4:10 gears
-New Ford ball joints
-New front brakes, calipers and discs
-Rebuilt NP270 transfer case
-New tie rod, tie rod ends
-RC dual steering stabilizers
-New rear driveshaft
-Rebuilt rear D60 w/4:10 LS
-35x12.50 18 Yokohama MT’s
Chassis:
-Fully sound deadend (Noico)
-Fully insulated ( Thinsulate and Thermozite)
-Flooring is Bedrug with 5/8” AC ply then G-Floor commercial vinyl
-Underfloor storage
-Rear A/C and heat (engine running)
-CR Lawrence wing windows
-New Fiberine 24” bubbletop with reinforced ply and windows
-10k lb tow receiver hitch
-New Aluminess front bumper
-New Aluminess rear bumper with large storage box
-JVC cd/DVD touch screen stereo
-upgraded Rockford Fosgate speakers
-8” Fosgate subwoofer w/amp
-New front carpet
-New re covered front seats
-Swivel front seats
Electrical:
-100ah Battleborn Lithium battery
-Renogy 40amp DC/DC charger
-Renogy 1000watt Sine wave inverter
-Renogy 200 watt solar with MPPT controller
-Victron battery monitor
-LED lighting throughout
-rear cargo lights
-rear aux LED backup lights
-front aux LED off road lights
-aux 12v and USB ports in bed area
-Mopeka Bluetooth propane tank level gauge
-Aux cab area lights
Amenities:
-3cu ft IndelB 12v refrigerator
-Sink /faucet
-rear exterior shower
-6gal Suburban Water heater
-26 gallon fresh water tank
-2.6 gum Seaflo water pump
-16k btu Suburban furnace
-Fantastic Fan roof fan
-Yakima 48”x 84” roof rack
-Maple cabinetry and storage cabinets
-Marine slam latches with soft close hinges
-Digital Honeywell thermostat
  • Like
Reactions: MSD
Saline
A few more photos:
MSD
Well Known Xplor’r
So...not bullet-proofed?
Honestly this doesn’t need bullet proofing, it’s not a bro truck that’s been tuned like a 7.3. It a van that actually de-tuned from a stock truck by about 100 hp. The only 6.0 liter van that needs bulletproofing is 2004 6.0 Van & it’s not even needed if do an EGR delete. Late model 6.0 psd are super reliable Especially the 2009. Everything that has been done to this van is all that’s needed it ready to roll. I’ve own numerous 6.0 psd 4x4 vans & had no issues. Never had to bullet proof because in a stock form & mild tune they have all the power you need…
Saline
Bump for a rad van. @Saline would you mind sharing how you mounted that roofrack and any photos you have of the roof/solar setup?
Thanks, it has been a fun project.
I used a standard Yakima Lock n Load rack and then fabbed sim simple aluminum mounts. The mounts bolt through the roof and interior wood structure. The mounts have butyl tape, then silicone around the edge and Dicor sealant on the bolt heads. The photos don’t show the Dicor.
Saline
The bed platform is 76" x 57 1/2" at its narrowest point. That puts it between a Full XL and a queen.
Saline
I can't stop myself from continuing to add to this van. I had the stuff sitting around so why not? I added functional fender vents and an air scoop to the Aluminess bumper.
lokoh
Sweet van. Can I ask what you used for the fender vent and the air scoop? Is this a kit or addition that is readily available? Or is this custom fabricated?
Saline
The fender vents are from a late 70's era Arctic Cat snowmobile of all things. This is the third set that I've installed on E series diesel vans. The front scoop was just a fabricated piece that I made.
iStan814
