2020 Ram 2500 Powerwagon + PCOR Tray & Canopy Ultimate Overloading Build - $106,000
samkooky
This is one the best overland build on a Ram 2500 platform you will find. The truck is the ultimate off roader / overland and is built to meet the perfect balance between capabilities, storage, ease of use and comfort.
It has been extremely well taken care off. Professionally cleaned and waxed every other months. Oil changed every 5,000miles. Up to date with routing maintenance and recalls.
The whole set up is suprisingly light for its size, thanks to the aircraft grade allumimium used by PCOR.
Professionally built by Exploration outfitters and then improved by local off road shops.
You are not only paying for the rig but the hundreds of hours that went into adjusting, testing and fixing the smallest detail. You are guaranteed a rig that is trail ready.
PRICE: $106,000 (will consider reasonable offers) - Not Trades
Watch a video walkthrough of the rig by clicking here.
You can also check the
IG page of the truck:
Serious inquiries only. I will not sell parts separately.
Factory Vehicle
- 2020 Ram 2500 Powerwagon
- Mileage: 36,000 miles
- 6.4L HEMI V8 Engine
- 8 speed transmission
- 4wheel drive
- Warn Winch Zeon 12k lbs (front bumper)
- Detachable sway bar
- Front and rear locking differential
- 4.10 axle ratio
- Electronic shift transfer case
- Powerwagon Level 3 equipment group (see Ram's website for details)
- Safety Group
- Towing technology Group
- Exterior Color: Delmonico Red
- Interior color: Black
Build
PCOR system
- PCOR Flat lat tray bed
- 3/4 canopy
- Dometic fridge & freezer
- Slidable kitchen top with storage + propanae/gas powered cooktop
- REDARC BMS 1230 along with a 1000W inverter and a 135 AH Gel Battery.
- 1150L of general storage
- 100L pressurized water tank.
- ARB compressor in one of the PCOR compartments.
Suspensions & tires
- Carli pinto suspension
- AEV 17x8.5 Kalta wheel
- 37x12.5 Goodrich tires KO2.
- Upgraded the rear coil with Carli HD coils for greater payload
- Firestone airbags with daystar cradle for potential heavy loading.
Roof system
- x2 Rhino rack pioneer platform: one in the front and one the rear of the vehicle.
Solar panels
REDARC 200W single panel installed on rooftop and secured with REDARC brackets
Lighting
- x2 Baja Lights LP9 and x2 LP6 on the front bumper
- x4 Baja lights spot lights on the side of roof rack
- x4 Baja lights rock lights and under the car.
Control
- SPOD inside cabin controls everything
Sun coverage
- Darche 270 Awning
Communication
- Yeasu 400-XTM ham radio, professionally installed in the cabin + antenna
Computer holder
RAM Mount for laptop (up to 17") installed in main cabin - Can also accommodate tablets
Additional storage
- Blue Ridge overland back seat panels and storage installed on back seats, including a car trash
PowerWagner
Good looking rig. Any idea of the GVWR and how close you are with all the accoutrements? Is it relatively easy to remove the goodies and just run the tray when you may want to shed pounds in order to tow with?
Houie
