sinuhexavier
1996 5 Speed Alpine White SD (No Sunroofs or power seats)
$3,746.78
147k miles +/-
$500:::ARB winch bar spring 2006
$500:::Warn 9.0 Winch synth line and EE shackle mounts spring 2007
$200:::2 IPF 900XS Lights factory wired spring 2006
$200:::Olivares Steering Components spring 2007
$450:::Olivares sliders spring 2007
$75:::Olivares Spring retainers Spring 2008
$50:::Stainless steel brake lines spring 2007
$100:::OME HD Shocks spring 2008
$200:::OME HD Springs spring 2008
$50:::Rubber Spring Isolators all the way around spring 2008
$50 :::EE Rear Shock Mounts spring 2008
$200 (ea)Tom Woods Drive shafts front and rear spring 2008
$250:::RTE Rear Links Spring 2008
New Leather on front seats Fall 2007
New Clutch spring 2007
Alpine CD player with Alpine amp and polk audio speakers spring 2006
AUX 12v (2) plug power in the back
Truck runs great, transmission is strong, leaks from oil pan, rear main seal, and oil cooler lines.
It needs a new battery, steering box, and cam shaft position sensor, it will also need tires in 20k. Would drive across country after addressing the camshaft position sensor and battery without hesitation. Here is the last big trip I did, 7 days of which were solo with hundreds of miles off road. 1.0 never left me stranded or even came close... Well there was that lame rotoflex issue once, but that was it.
Both rear quarter panels are crushed you can see in photo and hood is dinged ever so slightly on the passenger side all the way in front you can see it in the photo. The paint is in immaculate condition.
Minor rust in usual places, door jams and alpine windows...
***THERE IS NO RACK AND NO REAR DOOR TABLE***
Not going to part it out, unless I don't sell it until Mid-FEb, although I have priced out what I would part it out for if that time comes...
Plesae direct all questions to sinuhe@greendotfilms.com, I am in the midst of a big project and am not hitting boards all that often.
$3,746.78
147k miles +/-
