elcoyote
Supporting Sponsor, Overland Certified OC0004
To be exact, the flexible panels require more square inches per watt than the glass panels. Amphorus flexible panels produce power better than glass monocrystalline or polycrystalline panels in low light situations (early morning & late afternoon or overcast). The amphorus panels also produce more power in high heat conditions than the crystalline panels. I know it is counter intuitive however the the best conditions for a solar panel are cold temperatures & clear skies (in our hemisphere, N. AZ & NM are the best solar areas in the country).I read somwhere the flexible type solar panels are 20% less efficent than the solid type.
Does anyone know for sure?
I am about to order 2x40 watt panels in a hinged frame or maybe a single 100 watt panel.
I have a Yamaha 1000 efs but I could do without it on most trips by recharging from the 2x770cca batteries and the 120 amp alternator in the landcruiser.
Solar requires planning. It is the same as understanding how much fuel your vehicle carries and what your MPG is. In solar applications, your tank is your battery, your gas station is your panel and your MPG is watts drawn from your battery.
If you use solar a lot, it will provide a better ROI from a cash & environmental perspective. Panel life expectancy is 15-20 years before deterioration is seen in output. This is based on 24/7 exposure. My philosophy has been to reduce my power consumption by using the best available low voltage & low wattage technologies to avoid the need for a higher output generator. For example I choose the higher cost, lower draw refrigerator (e.g. Engel) over the lower cost, higher draw competing product.
My power analysis for my cabin showed that it was less expensive to replace low cost current technology 110v appliances with higher cost best technology 12v & 24v appliances. This allowed me to downsize the photovoltaic array rather than use a generator over the life of the system. It's long term thinking over short term thinking tailored to the application.
