After I saw the 1983 Toyota pickup advertised in the "For Sale" section, I just couldn't stop thinking about it as an alternative to the Earthroamer XV-JP as a go-anywhere adventure camper.
Here's a comparison of specifications of the two vehicles, starting with the chassis. I'll post a comparison of the campers soon.
Chip Haven
Expedition Camper Comparison
Custom 1983 Toyota long bed pickup camper (Chevy V8)
http://www.expeditionportal.com/forum/showthread.php?t=24434
http://www.wanderthewest.com/ads/cat-2/ad-118/
and
2009 Earthroamer XV-JP Jeep camper
http://www.earthroamer.com/tab_xpedition_vehicles/xvjp1_overview.html
Part 1: Chassis
Engine
Jeep 3.8L V6 202 hp and 237 ft-lbs of torque
Toy 6.7L stroked Chevy V-8 small block, estimate 350 hp, 375 ft-lbs
Fuel capacity
Jeep stock 21.6 gallon tank
Toy stock 16 gallon tank, plus 13.5-gallon auxiliary tank (gravity flow)
Fuel economy with camper during expedition use
Jeep 16 mpg (per Scott Brady)
Toy 15 mpg (per owner)
Transmission
Jeep 4-speed automatic transmission 2.84 first gear, 0.69 overdrive
Toy NV-4500 5-speed manual , 5.61:1 first gear, 0.75 overdrive.
Transfer case
Jeep NV241 or Rock-Trac, 4.0:1 low-gear ratio.
Toy Dual Toyota transfer cases, front case 2.28:1, rear case 4.1:1, twin shifters
Final Drive
Jeep 4.10
Toy 4.11
Final Low Crawl ratio
Jeep 47:1
Toy 215:1
Front axle
Jeep Dana 44, Tru-Lock e-locker, electric sway bar disconnect
Toy stock Toyota axle, Tru-Trac gear proportional locker, manual sway bar disconnect
Rear axle
Toy Dana 60, ARB air locker
Suspension
Jeep Heavy duty coil springs, 3 inch lift, Bilstein shocks
Toy National Springs, lift unknown, Rancho 9000 shocks
Toy long rear suspension arms for extra articulation
Brakes
Jeep standard Jeep disc/disc
Toy Land Cruiser brake cylinder, Land Cruiser vented discs, 4Runner calipers in front
Toy Rear disc brakes
Wheels and Tires
Jeep Goodyear LT285/70 R17 (32.7 in diameter), 8 ply, alloy wheels
Toy BF Goodrich 33x12.5x15 (32.5 in diameter), alloy wheels
Protection
Jeep heavy duty steel front bumper and grill hoop (by AEV?)
Jeep Heavy duty steel rear bumper with swing-out tire carrier
Jeep custom skid plates and rocker panel sliders
Toy custom Reunel steel front bumper, 1/4-inch steel, 1/2-inch mounts
Toy custom Reunel steel rear bumper, 1/4-inch steel, 1/2-inch mounts
Toy custom sliders, skid plates ?
Recovery
Jeep Warn 9.0 radio control front winch with 50' 3/8-inch diameter nylon line
Toy Warn 8.0 front winch with cab control
Auxiliary Driving Lights
Jeep HID driving lights and Halogen fog lamps in bumper
Jeep four PIAA 600 HID off-raod driving lights above cab
Toy Hella Rallye 4000 (one driving, one cornering) on bumper
Toy fog lamps mounted within bumper
Safety systems
Jeep Electronic Stability Program, Electronic Roll Mitigation, Traction Control Hydraulic Brake Assist
Jeep Advanced multistage front air bags
Toy none
Warranty, chassis
Jeep Chrysler limited lifetime powertrain warranty ?
Toy none
Miscellaneous
Jeep engine-driven air compressor and air tank
Jeep air horns
Jeep anti-theft engine immobilizer switch
Toy Firestone Ride-Rite air compressor and tank with regulator
Toy 160 amp alternator and Premier Power welder
Toy air horns
Chip Haven
and
Part 1: Chassis
Engine
Fuel capacity
Transmission
Transfer case
Final Drive
Jeep 4.10
Toy 4.11
Jeep 47:1
Toy 215:1
Front axle
Rear axle
Suspension
Brakes
Wheels and Tires
Protection
Recovery
Safety systems
Toy none
Warranty, chassis
Toy none
Miscellaneous
Jeep air horns
Toy air horns
