That's looking good Henry.
I like the idea of being able to take the TW with you on your trips.
Thank you.
I've been thinking of building one myself and I'll steal you idea if given a chance...Years ago I built a bike trailer with a sliding carriage and it worked out great. I could adjust the axle placement by 18" with a screw jack and keeper bolts...The sliding carriage really came in handy for balancing the trailer.
Your build has me thinking about my future build and I'm thinking, what if I attached the gas can holder (5 gallon military type), propane tank, fenders and springs to the carriage and made it with a 24" slide capabilities? On a trailer like yours balance would never be an issue...
But, on the flip side of the coin!
If the bike were on the front end of the trailer and had a sliding tongue and sliding suspension carriage, like I described above, then a person could still get in the trailer through the tailgate. The sliding tongue would be to allow cornering clearances with the bike in place, and could be shortened when not. The carriage would alleviate the balance problem. A guy could effectively use a bathroom scale under the tongue to get it on the money. Course the carriage would mean a little more added weight. But that wouldn't be that much if you used the frame rails as the upper support and angle iron for the carriage frame and guides. But, in retrospect, the sliding tongue would really have to be heavy duty to carry that heavy KLR.
Awesome! Ideas are really spinning! That is what I like!
Mine is adapted to do what it can with the platform I have to work with.
If I were to build one the front mount would be the way to go. I can already see that it is going to be a pain to access the box with the TW on the back. The tailgate is blocked and the lid can only open about eight inches since the handlebar rides over it. That means the bike has to be unloaded for most everything. A front mount would at least leave the tailgate accessible.
There are other problems with the rear mount. Declination angle is poor. No good way around that. I will have to unload and move the carrier to the front mount to carry.
Next is the "bounce". At the back any vertical motion is amplified. The wheel may travel upward an inch , but farther back it will be more. Think of the forces when you wiggle a stick. Farther back is more leverage and a longer whipping action. Those are not issues on a front mount.
Aerodynamics. On a front mount the bike gets the benefits of the tow vehicle breaking the wind. On a rear mount it is an obstacle for the air flow in a place where a nice low rolled over back is needed.
I can see how an axle "cradle" slider might be handy. Much like a fifth wheel slider. I wonder though if it would get little use once the sweet spot or compromise is found? If the load change was extreme and frequent, it might be an advantage nice to have. You will have to weigh the need with the expense. By expense I mean both time and materials for the need.
My trailer is longer than I really need inside. I use a load bar to secure the cargo. This allows me to shift the load forward or backward as needed to adjust tongue weight. now that I know where I am after weighing it last night, I feel better about my direction. I think I will be permanently mounting the water tanks forward now. I need to move my hitch box forward a little and I should have room for them on the front of the box. That adds about 100# tongue weight , but I can move the load inside back to compensate when not carrying the TW on the back. If I plan the load correctly, as the consumables diminish the load should equally reduce both front and rear.
I think I would be tempted to build for your application. That is what the Teepee hauler did for mine. It probably worked perfectly for that application. Now I am adapting for mine. Not the best way to go always.
If the future of mine is a full frame instead of the unibody construction, I will likely locate the axle forward and move the bike to the front. I do need a hitch on the back as a recovery point, so that I will retain. There are just too many reasons why a front mount makes more sense.
