Fuso Canter versus Isuzu
Bandicoot
Again, I'm no expert in this area, but this was my take on why I ended up wanting the Canter rather than the Isuzu. However, I realise some of these points may attract debate!
The two main competitors in Australia for this segment of the market are the Fuso Canter and the Isuzu NPS.
In my opinion, the Fuso has significant advantages including:
o Isuzu has electronic transfer activation (Hi/Lo and 4WD) rather than lever/cable operation
o Isuzu requires DP filter on exhaust to meet ADR (Canter has only EGR and Catalytic converter), hence Isuzu:
 Cannot get any water in the exhaust, giving it a very poor wading depth
 More maintenance
 Special engine oil
 Potential fire risk during regeneration while vehicle is stationary
o Isuzu front anti-roll (front sway) bar is low and can be easily damaged. Canter has no anti-roll (front sway) bar which improves off-road wheel articulation
o Canter has best rear limited slip rear diff
o Canter has narrower chassis rails so more flex which means more wheel travel and better traction
o Isuzu has higher chassis so higher centre of gravity (COG)
o Canter is 200 kg lighter so can take more load before reaching GVM (Isuzu and Canter have same GVM)
o Canter has more torque
o Isuzu with the EC body on it would not fit into a standard 20 ft hightop shipping containers
o The Isuzu is not sold overseas in as many countries as the Canter (which is part of the Mercedes Group)
Bandicoot
whatcharterboat
However, I realize some of these points may attract debate!
You bet. I'll edit in some pics when I get the chance later. Going to bed.
The NPS v FG thread was started a few months back but I sort of gave up on the idea of continuing it. I really didn't want anyone getting the wrong idea (from me anyway) about wether or not one truck was better than another for the purpose of a camper conversion. One truck is far far better engineered. Every component on one when individually compared to the other, right down to the bolts that hold it together is better engineered, stronger and more comprehensive. That still doesn't mean that one is perfectly suited to a camper conversion. There is alot to consider and money is always an issue. One truck is around $10k more but you probably get much more than $10k worth of truck quality. If you intend to turn the vehicle over regularly maybe you don't need the extra $10K of truck.
Example.
Fueltanks.
Nps tank is rectangular and only 800mm long. FG is cylindrical and about 300mm longer so that's 300mm of bin length you loose if you're fitting bins anyway. That's alot when every spare inch is used.
NPS is 140 litres. Fg is 125 but because of the round shape only 115 is useable. 25 litres difference.
NPS is has a large locking filler cap. FG doesn't.
Now obviously one tank is a hands down winner over the other but you may intend to have custom made tanks fitted which makes the debate irrelevant anyway and you can certainly build a locking flap aver the cap but I hope you can see my point. The question of one being better than the other is a very complex "debate".
The audio unit in the NPS is the best thing ever, NAV, 3 camera inputs with split / touchscreen, bluetooth , phone, video, USB ports, etc. Probably worth $3k by itself. The new FG just upgraded to a CD from a cassette tape player in the previous 649 model. Laughable but see the difference. Again you may be planning an AVIC, VMS or PC based Nav system or similar so it could also be irrelevent too.
So hope you don't mind me throwing in my 2cents. I've been working on both of them for 8 years now and had a SWB Canter, an Isuzu, a 2wd FH Canter and a 10 ton Hino for the 4 years prior to that.
Ask Engineer about how many FG "transfer activation" cables he's had to repair after they've chaffed through on the crossmember. Was always an issue. Isuzu introduced electric/vauum activation on the FSS many years back and have only just introduced it to the current model NPS.
As a matter of fact, the NPS has always had cable activated gear selection. the FG only got it on the 84 model after doing away with the old linkages and rods. The FG is always one step behind. Did you now all the FG's will have Airbags from now on?
 More maintenance
The DPD is the big question mark alright. I really don't know how the FG can get away without it. The stuff that comes out of a common rail diesel exhaust is just so harmful. What's Fuso going to do about Euro V?. DPD? Urea? This is a big issue allright. NPS's have out sold FG's in the rural fire brigades and mining due to their fitment of airbags and now they are causing problems with the DPD's. The mining guys are sorting it out slowly and the fire brigades are apparently getting exemptions to loose the DPD's but what are we going to do? I'm hoping some of the NPS owners jump in here about the wading depth and safe operation of the DPD burn. Not sure about more maintenance?
And can be disconnected in 5 minutes. Even quicker with "disconnects" fitted. Also offers excellent handling and reduces body roll. Very important for any truck with a high CoG and most of these things have been lifted too with different springs, tyres etc which makes it even more useful. Not saying it doesn't happen, but I haven't seen a damaged one yet either.
Every part of the drive line on an Isuzu is heavier and stronger. The rear diffs are no exception and they very tight. If anything, too tight. Offroad they are fantastic but then so is the FG LSD. Why would you say this???
Canter rails and old model NPS's are 750mm apart. The current NPS went to 850mm, I believe to give wider base for mounting of bodies. This is a good thing. The bodies put less stress on the chassis during body roll. Gee, I thought this was one of the NPS's best features. It certainly gets the shock absorbers a lot closer to the wheel at the rear. Have a look at how close the rear shocks are together next time you're under an FG.
Again, debatable. Our last NPS ended up with the body 65mm lower than when we mount to an FG. On the next NPS we're going to lift it up to the same height as an FG cause we didn't get the rear wheel clearance we hoped for. The CoG of the body is theoretically no different. The only CoG difference would be the rear section of the chassis rails. Also the NPS is straight so you don't need the same heavy stringer setup as on an FG. Yeah. CoG is really debatable.
And the NPS is 200KG stronger. Mainly because the FG chassis is only 4.5 mm and the NPS is 6mm and is also a much bigger section. Sure on a 4.5Ton truck 4.5mm should be OK and you are right ESPECIALLY if you're trying to keep to a tight 4.5ton GVM limit. Also as I said before, everything on the NPS is bigger and there is just more gear like the sway bar mentioned, and the heat shield behind the cab, bigger brakes, etc. All good gear that the FG doesn't have. As an example >> FG tailshaft loose next to a NPS. See the size difference.
Hey , everything I've written here is from my head, so if I get the fine detail wrong , please someone jump in. The FG has 470nm and the NPS only has .....420nm. At least that's what the brochures say. This is just plain misleading.
The FG84 engine is an awesome bit of kit when compared to past generations but 470 nm arrives with a bang. If you drive a new cab chassis at the dealers, man , they feel like a sports car. Very peaky. Drive the NPS and it certainly doesn't feel anything like it. Very tame by comparison. Load them both up to 6 ton and it's a very different story.
I've probably made over a 150 passes down the dragstrip in an FG and 75 or so in an NPS. Different size wheels, tyres and weights. At full 6ton GVM, the NPS is close to 15 to 20kms faster at the 400m (1/4mile) line.
OK, so how can the NPS with supposedly less torque do this???? They have variable turbo geometry. Insane engineering. The more I learn about it the more blown out I am. For example, they say they make turbo timers totally unnecessary cause they open up straightaway and take all the pressure off the vanes as soon you back off. Must make them last alot longer by this.....Anyway the result is an extremely wide torque curve. The 419nm is available from 1600rpm to 2600rpm. Incredible really. So when you're cruising at 100kph at around 2700rpm depending on you wheels you still have almost 420nm. A standard turbo cannot do this. Sure, a bigger turbo will produce more torque higher in the rev range but at the sacrifice of the bottom end. This is like swapping turbos on the go and in real time.
Compare the area of torque curves not just the peak figure. The variable turbo is so undersold and misunderstood. They are just awesome on big long hills. Again more electronics to go wrong but hopefully answers the statement of which actually has the most torque.
Yeah I've heard that one before too. Sorry can't (and won't ever on ExPo) comment on the EC body but an NPS Isuzu WILL fit in a standard 20 ft hightop shipping container with someone else's body on it.
If you are talking specifically about the NPS model, then probably not but Isuzu is one of the biggest truck manufacturer's in the world I couldn't say for sure about dealer locations but I'm guessing they don't sell so many trucks without plenty of dealers. In Australia they have by far the highest percentage of all truck sales and as of this year have held that title for last 20 years. I think it was more than a 1/3 of all truck sales. Fuso was in second place with about half as many sales as that but the gap had widened from the previous year. 3rd was Hino, then UD. Everyone else was way back. Sorry OT.
In the USA, Isuzu again claim more cab over sales than any other manufacturer. Now sure, the NPS isn't sold there but the NPR is and with much of the same parts (and more options than here). I know of at least one NPS owner planning a trip through SE Asia and beyond. He seems to think there will be more than enough dealer support. One of the reasons he chose the truck to begin with.
I doubt it would be hard to find parts or service personnel for either truck, no matter where you were.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
I still haven't touched on cooling systems, brakes, chassis construction, EGRs, heat behind the cab, mirrors, aircleaners, suspensions, wheels, tyres (well the last 3 would hopefully be replaced anyway on either truck cause you wouldn't leave them on a good camper if you could afford it). Tried to be as honest as I can here. One thing I agree with that's been said on ExPo before about vehicle selection for a camper conversion is that truck / diesel mechanics (and I would add people in general with a background in the trucking industry) tend to buy Isuzu's in Australia. Drivers (even ex commercial drivers) and most stepping up from a typical Landcruiser type 4x4 buy Canters.
nugget
I would have thought that one of the main problems with the NPS is that it doesn't come in a short wheel base, especially for anyone wanting to keep to the 4.5T GVM.
Also the suspension upgrades are tried and proven on the Canter but seem to still be developmental for the NPS.
whatcharterboat
Hi Wayne, Well sort of. Its more a case of the NPS being stronger (and heavier )than it needs to be when downrated to a 4.5t GVM (aka NPS 250). Because the new NPS doesn'n have a centre bearing and 2 piece tailshaft like the previous models and the MWB FG's, they would be really easy to cut down to any shorter wheelbase you like. Literally have the tailshaft shortened, slide the spring hangers forward and cut the end off.
The wheelbase of the new nodel is 3395mm . An FG MWB is 3460 ans the SWB is 2860mm ( I believe shorter than a Landcruiser BTW).
This is true. Regarding the suspension, both the old NP's and all the FG's have undergone very minor changes (if any) from day 1. Engines and interior etc, have had improvements with each new model. With the new model NPS , they basically wiped the drawing board clean and started from scratch. No carry over components that I can see except maybe the diffs. Not sure. That's left every one scratching their heads a bit.
If you were talking about standard suspension, that'd be different. One truck clearly has much more load carrying capacity although on paper they are both 6ton. No matter what, as far as a camper conversion is concerned, both trucks as standard do not provide a ride that you could describe as pleasant.
nugget
Hi John,
Understand what you are saying but wouldn't shortening the tailshaft increase the angles..would that induce other problems/wear? The other issue with shortening an NPS of course is the $'s..just makes an already more expensive truck even more expensive.
I am looking at it purely from a camper conversion point of view.
It just doesn't seem to me that there are "in developement" projects, no one has really come up with a good NPS suspension setup that has been road tested and given the big thumbs up.
If I am wrong it might be enough to swing me back to the NPS!!
Again from a camper conversion perspective, most of us are not going to do 1,000,000 kms. A lot of what we will do is hard k's in the bush but 150,000- 200,000 kms takes you around Oz more times than I can calculate so the relevant issue is .... in that scenario, is the NPS worth the extra $'s, or would you be better off spending the extra $'s on a suspension kit for the Canter.
I guess in 4WD terms where I am coming from, it is very much a Toyota Landcruiser/Nissan Patrol argument. Both were hard as nails but the Patrol 10k cheaper.I was never let down by my Patrols.:sombrero:
engineer
Hey John,
Might wan to be careful cutting down that exhaust, very touchy subject matter.
Something about it changing the DP and stuffing it allup. Might be wrong though.
The other cause for concern is Isuzus, change it and no warranty issue.
I hope they upgraded the diffs, which I'm sure they have the fss diff in the NPS now, the old one was as weak as .....
whatcharterboat
Yeah, you can just see it next to the tailshaft in the pics. Notice all the extra webbing on the outside. I think it's the same as the 10ton FSS. Actaully I think the whole driveline is. So that means an NPS 250 is running a driveline rated at more than double what it needs to be. Isn't that overkill??
I know a FSS computer and DPD will drop straight in and give 205hp. One of the dealers did it for a guy I know and it was still covered under warranty. That's how detuned they are.
Anyway, I always thought the earlier model diffs were a bit too tight for the road and copped more of a flogging from tight turns on the bitumen. More suited to offroad. One day someone will bring out a proper airlocker for all these trucks and we won't have to think about LSD clutch packs ever again.
No. You are right. They are OK to re run from the DPD choke (looks like a 2nd exhaust brake) to the tailpipe but all bends have to be long radius and the length is obviously tuned. Also the outlet has to face rearwards or the air pressure will give the DPD sensors a false reading.
Yeah I know what you're thinking but hey, it is the future now and this is only just the beginning of emmissions control. Wait till Euro V hits (next year I was told).
Chocko, I'd just be really happy with an old FG 637 or '02 NPS like "1 Engine" but you can't stop what's coming.
whatcharterboat
Not sure about that. The angle on the NPS is really flat as standard. The MWB FG transfer case output shaft setup to take the flat angle of the first half of the tailshaft. When they build a SWB all they do is remove the first half of the shaft, centre bearing and that crossmember so the SWB final tailshaft ends up at quite an angle but I don't believe it's ever been an issue on them.
Yep. Dead right. I wouldn't touch it anyway but then I prefer the longer wheelbase FG too. If you interested they both have a turning circle of 13.6m and the SWB is 11.4. Wayne, bottom line is if you wanted to shorten an NPS, you could and I don't think it would be a hard job for any workshop. We just stretched an FG 500 mm last week. Took a couple of days and that would have been a lot more involved.
Not yet. Plenty of stuff going on behind the scenes though. The FG definitely lends it to far more modification. Judging by your H3 you aren't going to keep things too standard anyway.
Again Wayne, you can see how complex the issue can be. One truck is better in most aspects but does that count when you intend to upgrade the suspension anyway. Does it matter if the NPS comes with these cool 17" tubeless Michelin XZT's and the FG still has split rims and Bridgestones when it's almost a given that you'll go with super singles too.
I
There you go. I was always let down by LC's but never a Nissan.
Amesz00
If you look at the specs the rear axle is rated at 6.6T! i think it must be out of an FSS, just shortened a bit.
My basic understanding of the VGT (variable geometry turbo) is that inside the exhaust housing it has fins or vanes which turn in order to change the direction and efficiency the exhaust flows onto the turbine, effectively changing the A/R ratio (giving a small ratio at low rpm, low flow, and a big A/R for high boost and flow).
The main reason they are very undersold is because for an aftermarket setup they are difficult to setup (due to the extensive electronics involved). However, i believe that the first Holset VGT's were not electronic, but operated via springs and air pressure (somehow).
Anyhow, as far as aftermarket, most guys chasing this kind of torque curve opt for twin turbos, setup in 'compound', which seems to suit diesels very well. also much cooler...:cool:
Oh yeah RE wheelbases;
we've had a 'shorty' canter, and now ive got a dualcab LWB. The SWB definetly has the advantage in maneuverability and tight offroad situations, but the LWB is much more stable on road, and on dirt (the SWB is a bit twitchy, will flick around if your not careful... but the LWB i have now will literally outrun my mates '80 series cruiser on a twisty dirt track...;P ).
As far as my opinion on best wheelbase, i think my next rig will be about 3150mm.
ozzyfishaman
Well I have allways gone the L/C route (Hence the NPS ) When I have Improved the vehicle to where I think the vehicle is right I have NEVER been Let Down and believe me I have a Vast Amount of Off Road Experience. As John said the build quality of the Isuzu is a step above the Fuso (at a cost) but everyone to their own.
When I was researching the two vehicles in the weight carrying capacity we have available in Oz, The Build Quality of the Isuzu sold me immediately, I have modified my Isuzu extensively so far, but in my case I need to get the truck to ride acceptable unladen (3700 kg) as well as laden around 5300kg.The rear is riding Very Nice the front unladen is acceptable, But not Perfect YET ,But believe me I will get it right.
All Terrain Warriors (John and Mark) have been VERY HELPFULL with my build and I believe they are the best in the Business ( World Wide) [/QUOTE]
There you go. I was always let down by LC's but never a Nissan.[/QUOTE]
Bandicoot
Hi WCB
First of all, I admire the time and effort you put into posting on this forum, and also your honest, open and candid comments.
Secondly, I don’t consider myself at all an expert in these areas; however, if a layman such as myself is buying a new base vehicle to be converted into a camper, at considerable expense, then it is certainly prudent to take the time to at least understand the issues as best I can, and not just rely on the gurus! In this sense, I’ve tried to do my homework to understand what is important to me, and what isn’t.
So at the risk of starting a David and Goliath battle here, I’m going to put forward a contrary view to you on the Isuzu and Canter.
I might add, that it appears from your comments that the comparison is a “no contest” as you see it; the Isuzu is just the better vehicle all round; it wins hands down! I wonder if we’ll be changing the sub-forum name to “Isuzu heavy truck....” (only kidding)!!
Every vehicle is a compromise of some sort; it just depends what you want to compromise on.
As I see it, there are two types of buyers for these sorts of vehicles:
Commercial buyers such as adventure travel companies or miners of the rural firies. In this case, the vehicle is likely to be driven by multiple drivers (who don’t own the vehicle or pay for the repairs on it), be fully loaded, be running much of the time to a fixed schedule (due to carrying tourists or being on other critical tasks), and generally would get a very hard life. In addition, commercial tour companies don’t literally “go bush”; they stay on beaches or on tracks, even if the tracks are rough.
Private buyers such as a husband and wife. In this case, the vehicle is likely to be driven by only one (or at most two) drivers (who do own the vehicle and pay for the repairs on it), be more lightly loaded (perhaps?), run up much fewer km on a more easy-going schedule and generally get much more TLC. The keen private expeditioners such as myself are much more likely to “go bush”, i.e. off track pushing through scrub just on a whim or by design. I like to smell the roses as I go bush!
I’m also reminded of what Tom Sheppard said in his excellent book that the key quality to look for in overland expeditioners is being “mechanically sympathetic” (or something like this). Any vehicle can be broken if it’s pushed hard enough!
So when I’m looking at this issue, I’m looking at it from the point of the private buyer.
So what are the things that are really important to me, as that private buyer?
• Not having a DP filter on the exhaust. This in itself rules out the Isuzu for me. The fact that the Isuzu could be in its regeneration cycle while I’m going through Spinifex or long grass and could easily kill the missus and me (as well as burn the countryside down) just rules it out. Further, my understanding is that it basically can’t go through any depth of water any more! This again rules it out as an off-road expedition vehicle.
• Staying under 4500 kg GVM. I accept what you are saying that there are probably other makes of camper including ATW that use the Isuzu base and are under 4500 kg. However, any motorhome based on the Canter is going to have a 200 kg advantage in payload over the Isuzu; this may not be a consideration if running at 6000 kg, but is a vitally important advantage is at 4500 kg. 200 kg is an additional 250 litres of diesel payload!
• Ease of repair in the field. In this case, a cable operated transfer is definitely an asset over something electronic.
I’m relying on what others have reported that the Canter rear LSD is a particularly good one, but if you are saying there’s no difference, then I have no basis to argue the toss on that one.
Regarding the audio system in the Isuzu, I like the Canter as it has 3 DIN slots of which two are available for audio and a UHF. This is more important to me as I’ve tried the small screens for GPS and they are (to me) almost useless. I need an A4 sized touchscreen tablet laptop!
Regarding the sway bar, in my opinion few (if any) people are going to bother to get out and uncouple a sway bar to go over some obstacles and then recouple it when they’re back on the track, then uncouple again for the next obstacle, etc. Who goes out and puts their FWHs in and out every time they need to go into and out of 4WD if doing this dozens of times a day—they just leave them in for the day. If the sway bar can be left detached (safely) over various road/track conditions then why have it? The fact is that Fuso has designed the Canter to not need a sway bar so the problem is “engineered away”.
In terms of the narrower chassis, I accept what you are saying that the Isuzu is better for mounting large or wide bodies on the back due to better stability. However, what if you actually don’t want to mount a large/wide body on the back? The EC body is quite low in height (with roof down, i.e. in travelling mode) and no wider than the cabin so the wider rails aren’t an advantage as the narrower rails definitely will provide more flex, which means better off-road capability?
I could be wrong on the lower COG, but perhaps this is one reason the Canter has avoided the need for the “wider rails for stability” or the “front sway bar”, i.e. by keeping the COG lower.
I didn’t realise the Isuzu could be set up to fit into a 20 ft container; if it can then I stand corrected on this one. Does that include bullbar and spare wheels?
The longer WB also comes at a price. The turning circle on the Isuzu is 13.6 m which is very much bigger than the Canter at 11.4 m. I can easily fit my Canter-based motorhome in ANY carpark (providing it has the height clearance) and regularly do, and then get out of it!
In general, I accept that the Isuzu gets “value” from its extra 200 kg by having larger/stronger components. However, is this adding value for me? Not if it means going over the 4500 kg, especially since my understanding (having read fairly widely on this) is that private expeditioners have generally been very happy with the reliability of the Canters? I guess we could (at the extreme) all go to Sherman tanks!
Finally, regarding the engine torque, I've very surprised at what you say. I have looked at the published curves and unless I've stuffed up, the Canter is better on both power and torque over virtually the engine RPM range (see attachments). On a torque or power to payload ratio at 4500 kg GVM, the Canter would be much better!
Anyhow, I have no doubt you'll rugby tackle me over some of these comments as well!
Bandicoot
  • Canter 4WD engine performance with Isuzu superimposed.pdf
1Engine
The bolt on business part of the mounting brackets is no problem.
If your truck is 12 volt & the sender is 24v from the donor truck, you will need to modify the wiring. Or obtain a 12 volt sender unit
Not sure of the FG wiring however the Isuzu senders have 2 +ve feeds- 1 for gauge; 1 for low level light & 1 -ve.
A resistor needs to placed in each of the +ve.
The resistor for the light needs to be the same resistance as the low fuel level light
The resistor for the gauge is about 600 ohms.
I would use 10 watt wire wound resistors
WonaWarrior
