Ballistic vs. Johnny Joints
AlexJet
I posted this in 4Runner/Tacoma/FJ part, but thought that Land Cruiser guys may have some info too.
Have anyone used any of Currie Johnny Joints or Ballistic Fabrication Joints?
Which one is better? Which one would be preferable for suspension build? What about reliability and easy of maintenance, availability of parts?
2.5" Forged Johnny Joint --- $40
2.63" Forged Ballistic Joint --- $46
thumbnail.asp
alexrex20
only the Ballistic is adjustable. when the loosen up due to normal wear/tear, the Currie must replace the bushings. with the Ballistic, just tighten the lock nut.
Nay
These are generally long life parts if you keep them greased. You won't go wrong either way.
AlexJet
What is the setup you are planning on doing?
Custom 3-Link on the back.
BTW, I've seen 2 different aproaches to the system. Which one is better? (Note that lower links are paralel to the frame rails)
1. The upper (3rd Link) is 70% of the length of the lower links.
2. The lower links are 80-85% of the lengthof the upper (3rd Link). Phisically it means that you have 3rd Link frame mount at about the same level as right lower link frame mount.
I'm reading many articles in Internet, but can't find the amnswer which aproach is better.
What are the benefits of each point of view vs. the other?
dieselcruiserhead
16 Years on ExPo. Whoa!!
I did regular old heims from Ballistic (and lots of their laser cut parts) and I thought they were great. I was advised to avoid the hard parts for street driven rigs because it transmits a lot of the road noise and interference to the chassis and in turn the cab... So I ended up using these poly bushings and they are super high quality and probably the route I would go personally...
http://www.summitmachine.com/store/...nents/poly-bushings/poly-bushing-2/index.html
Nay
No way a poly bushing can take the type of articulation being designed into the rear 3 link. Poly can deflect (compress) fine, but it lacks the twist characteristics of even basic rubber.
EXP-T100
Go with ballistic
I used currie joints before and they are a pain in the ace. They now offer a tool for $80!! To put it together and take it apart now but if you don’t have that you need a press and some sockets. Mine were suppose to have 30* of twist so 15* up 15* down well I only could get 5* before ball center would hit the cage.
The ballistic joint comes with a lifetime warranty! And there tool is only $31. The cage is threaded, just twist on the spanner nut and put in the set screw. Its a lot more user friendly than currie's joint. Pay a little more you won’t regret it.
playhard
I have been running JJ's for several year on my traction bar. I do a lot of business with Sam's Off Road. They have been using them since the Currie's came out with them. If you have to rebuild them, you can put them back together by using 2 C clamps.
I have no experience with ballistic.
flipstick
