BigJimCruising
Sounds good to me! I'll see you all there. I didn't know the old Fat Burgers chain was still around! Is it as good as the LA one?
Does someone want to post this on the meeting forum?
We have multiple threads pointing out the illegality of a ham radio modified to operate outside of the designated ham bands, so what are the legalities of using an aircraft radio to talk to aircraft? I'm thinking legitimate or emergency use, not "hey Hun, land that thing the pizza's here!"
I suspect that using the SPOT when you've got the other two tools (phone and radio) did complicate things, because it's only a one way communicator. I think that's lower on the totem pole when you've got phone coverage.
I think the phone would be #1 to use but if you don't know your coordinates then the SPOT comes in handy, which I think it helped here.
Check in your ARRL repeater guide (you have one right?) for machines, in areas you travel, that are LiTZ capable.
LiTZ stands for Long Tone Zero and means that holding down the 0 (zero) key on your DTMF pad for 3 seconds, the repeater will open a link directly to a person designated to handle emergency traffic.
The machine may be set up so when it receives a LiTZ it will autopatch you to a 911 operator or it may direct you to a ham designated to handle emergency traffic. Either way you'll get someone skilled at forwarding emergency messages.
Here on the front range we have a wide area coverage machine that, when you send a LiTZ, opens a link directly to the Colorado State Patrol dispatch center in Denver.
For more info on LiTZ there is a short chapter in the front of the repeater guide.
I'm a novice amateur, meaning I'm very new to HAM and don't really know what I'm doing yet. Last weekend on the trail we found an injured motorcycle rider that needed a helicopter evac. The Rider had SPOT, and we had cell phone coverage so we used both and did not need to ping a repeater to make contact with rescue personnel. I had a full listing of all the local repeaters, but did not attempt to use them because of the cell coverage and SPOT availablity. SPOT was used as requested by the victim because the recovery would be insured beyond just basic healthcare.
The first rescuer to arrive was a fixed wing Sheriff's aircraft that just circled the site. We wanted to communicate with him to let him know that we absolutely needed an helicopter for our patient, not a ground based or fixed wing transport.
Is there a way for my dual channel 2m/440 Icom 208H HAM radio to communicate with the aircraft? I tried raising him on 146.550 (Ham 2 Meter Ham FM Simplex National Emergency Frequency) and 146.520 (National Simplex Frequency) but was unsuccessful.
What do you recommend in this circumstance to communicate with the rescue teams?
Again, we used SPOT because of the insurance policy that comes with it
I.......
In a true emergency, use what you need, as wisely as you can. Ain't nobody going to come arrest you for using a radio to save a life.
